Buzzer for High and Low alarm
Posted: Sun Oct 27, 2024 1:51 am
Mornign,
My 2 heaters failed 3 days ago and i didnt notice until yesterday. Luckily the tempos only dropped to 22 so maybe dodged a bullet there.
Anyhow I was trying to setup an audiable alarm but cant get it to compile.
I have tried adding the following to my code but get an error
boolean buzzer=false;
if (ReefAngel.Params.Temp[T1_PROBE] >= 300 || ReefAngel.Params.Temp[T1_PROBE]<= 230) buzzer=true;
The compile error is
Compilation failed for Appleseed.ino: Details: Appleseed.ino: In function 'void setup()': Appleseed.ino:139:25: error: 'class ReefAngelClass' has no member named 'BuzzerOn' Appleseed.ino:139:53: error: 'class ReefAngelClass' has no member named 'BuzzerOff'
I am using an RA Plus.
The entire code is as follows
Andy
Andy
// 07-08-2024 editied names and set port 3 to auto on
//#include <RA_ATO.h>
//#include <Wire.h>
//#include <OneWire.h>
//#include <RA_PWM.h>
//#include <Salinity.h>
//#include <IO.h>
//#include <ORP.h>
//#include <AI.h>
//#include <DCPump.h>
//byte vtechmode;
//byte vtechspeed;
//byte vtechpercent;
boolean bFeeding = false;
byte x = 6;
byte y = 2;
byte t;
char text[7];
//Custom Main, Graph & Menu
// ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.DrawText(3, 255, 6, 2, " Reef of Low");
ReefAngel.LCD.DrawDate(7, 120);
// vtechmode = ReefAngel.RF.Mode;
// vtechspeed = ReefAngel.RF.Speed;
// vtechpercent = ReefAngel.RF.Duration;
ReefAngel.LCD.Clear(255, 35, 20, 20, 85);
// ReefAngel.LCD.DrawText(0, 255, 18, 21, "EcoSmart Mode");
// if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 25, 31, "Constant");
// else if (vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD, 255, 25, 31, "Lagoonal");
// else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD, 255, 25, 31, "Reef Crest");
// else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 25, 31, "Short Pulse");
// else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK, 255, 25, 31, "Long Pulse");
// else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA, 255, 25, 31, "STM_NTM.");
// else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA, 255, 25, 31, "Tidal Swell");
// else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE, 0, 45, 31, "Night");
// ReefAngel.LCD.DrawText(2, 255, 32, 42, "Speed");
// ConvertNumToString(text, vtechspeed, 1);
// if (vtechspeed )ReefAngel.LCD.DrawLargeText(0, 255, 35, 51, text);
// ReefAngel.LCD.DrawText(23, 255, 32, 62, "Duration");
// ConvertNumToString(text, vtechpercent, 1);
// if (vtechpercent) ReefAngel.LCD.DrawLargeText(0, 255, 35, 70, text);
ReefAngel.LCD.DrawText(0, 255, 10, 80, "T1");
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 10, 88, text, Num8x8);
ReefAngel.LCD.DrawText(0, 255, 50, 80, "T2");
ConvertNumToString(text, ReefAngel.Params.Temp[T2_PROBE], 10);
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 50, 88, text, Num8x8);
ReefAngel.LCD.DrawText(0, 255, 100, 80, "pH");
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO, 255, 85, 88, text, Num8x8);
ReefAngel.LCD.DrawOutletBox(12, 100, TempRelay);
ReefAngel.FeedingModePorts = Port4Bit; //| Port6Bit | Port7Bit;
// ReefAngel.WaterChangePorts = Port4Bit | Port7Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
// ReefAngel.Relay.DelayedOn( Port4 );
ReefAngel.Relay.On( Port5 ); //MP40
ReefAngel.Relay.On( Port6 ); //MP40
ReefAngel.Relay.On( Port7 ); //Return
// ReefAngel.Relay.DelayedOn( Port8 ); // Used By Cooling Fan
// ReefAngel.DCPump.FeedingSpeed=100;
// ReefAngel.Timer[FEEDING_TIMER].SetInterval(2100);
ReefAngel.Timer[FEEDING_TIMER].SetInterval(4000);
ReefAngel.StandardHeater( Port1, 250, 255 );
ReefAngel.StandardHeater( Port2, 250, 255 );
ReefAngel.StandardFan( Port8, 256, 260 );
// Define Relay Ports by Name
#define Heater 1
#define Heater 2
#define ReefWave25 3
#define Skimmer 4
#define MP40 5
#define MP40 6
#define Return 7
#define Fan 8
ReefAngel.Portal( "Appleseed" );
