Old Wifi attachment
Posted: Mon Dec 30, 2024 3:22 pm
by Iratus
Hi!
I cant find anything about solid blue light, only blinking.
The attachment have been disconnected for probably 2-3 years, do i need to re program it?
Best regards
Fredrik
Re: Old Wifi attachment
Posted: Mon Dec 30, 2024 3:30 pm
by brennyn21
Hi Fredrik, you will need to upload the new firmware to your wifi attachment using Tera team as well as reinstall your code using the online webwizard
Link for the wifi attachement is below unzip the folder download tera team. Change the Wifi SSID and Password in the ttl file and use Tera team to flash it.
Tera Team Download: https://github.com/TeraTermProject/tera ... rm-5.3.exe
Wifi Attachement FirmWare: forum.reefangel.com/firmware/updatewifi.zip
WebWizard: forum.reefangel.com/webwizard
Posted: Tue Dec 31, 2024 5:35 pm
by Iratus
That was a quick reply!
How many cycles dos it take for the macro to complete?
Posted: Tue Dec 31, 2024 5:38 pm
by brennyn21
Just once should do it if I recall correctly.
Posted: Sun Jan 05, 2025 12:49 pm
by Iratus
That did not work, i still have a constant blue light and no info in Tera Term
It keeps restarting and this is the last popup after a cycle
https://drive.google.com/file/d/1rq58mY ... sp=sharing
Posted: Sun Jan 05, 2025 1:06 pm
by brennyn21
Is it a slow blink blue or fast blink or just solid?
Posted: Sun Jan 05, 2025 4:08 pm
by Iratus
It is solid
Posted: Sun Jan 05, 2025 6:44 pm
by brennyn21
What does the output show in the terminal? Also if you have a space in your Wifi SSID make sure you put a $ in place of the space. For example, if your SSID is called "My Wifi" then it would be "My$Wifi"
Posted: Mon Jan 06, 2025 2:29 am
by Iratus
Output, where? I have no spaces in SSID
And this is what i get after one cycle when done,
https://drive.google.com/file/d/15B2Gzc ... sp=sharing
Web wizard cant find the attachment.
Posted: Mon Jan 06, 2025 2:37 am
by brennyn21
You are using a usb-ttl cable correct? Once you click okay if should show output in the Tera Team Terminal. Can you send picture of your wifi attachment? I'll take a picture of the process later today. Once you click okay it should run through the process and then the start Wifly Module configuration will show again. Just ignore this as you only need to run it once. Then using the webwizard you need to upload code to your Reef Angel Controller Make sure you use chrome or edge and download the plugin first.
Posted: Mon Jan 06, 2025 4:03 am
by Iratus
Posted: Mon Jan 06, 2025 11:16 am
by brennyn21
- In Tera Term, go to 'Setup' -> 'Serial port'.
- Choose 57600 baud.
- Then, go back to 'Control' -> 'Macro' and reopen the .ttl file.
Posted: Fri Jan 10, 2025 8:18 am
by Iratus
I have done that without results
Posted: Fri Jan 10, 2025 4:52 pm
by brennyn21
Very odd, I will send you a PM maybe its a hardware failure of the wifi attachment.
