CODE WITH TEMP PROBE PROBLEMS
Posted: Thu Jan 23, 2025 10:07 pm
THINK I MAY HAVE CREATED THE PERFECT CODE FOR ME, BUT PROBLEM WITH IT IS MY SUMP TEMP ON DISPLAY KEEPS FLUCTUATING FROM SAY 78.5 TO 0.00 ABOUT EVERY MINUTE OR SO??? THEN MY ROOM TEMP PROBE TEMP DISPLAY HAS A GREEN BACKROUND TO IT, AND NOT SUPPOSED TO. THE SUMP FLUCTUATIONS ACCUR REGARDLESS OF WHAT PROBE IS CONNECTED BETWEEN THE 3, HAVE SWITCHED THE PROBES AROUND AND IT STILL DOES IT. ANY HELP APPRECIATED....BELOW IS THE CODE
const char menu1_label[] PROGMEM = "Feeding Mode";
const char menu2_label[] PROGMEM = "Water Change Mode";
const char menu3_label[] PROGMEM = "Cloud On Demand";
const char menu4_label[] PROGMEM = "Clear ATO Timeout";
const char menu5_label[] PROGMEM = "Set Clock";
const char menu6_label[] PROGMEM = "Calibrate pH";
const char *const menu_items[] PROGMEM = {
menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label};
byte DaylightPWMValue=0;
boolean ForceCloud=false;
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ForceCloud=true;
ReefAngel.DisplayedMenu=RETURN_MAIN_MODE;
void MenuEntry4()
ReefAngel.ATOClear();
void MenuEntry5()
ReefAngel.SetupDateTime();
void MenuEntry6()
ReefAngel.SetupCalibratePH();
byte x = 6;
byte y = 2;
byte t;
// Parameters
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.Clear(COLOR_INDIGO, 1, 11, 132, 11);
ReefAngel.LCD.DrawText(COLOR_INDIGO,255, 1, 102, "----------------------");
ReefAngel.LCD.DrawText(COLOR_INDIGO,255, 1, 126, "----------------------");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,56,110, "ATO");
ReefAngel.LCD.DrawText(COLOR_NAVY,255, 2, 109, "*");
ReefAngel.LCD.DrawText(COLOR_NAVY,255, 2, 121, "*");
ReefAngel.LCD.DrawText(COLOR_RED,255, 45, 111, "H");
ReefAngel.LCD.DrawText(COLOR_RED,255, 45, 121, "I");
ReefAngel.LCD.DrawText(COLOR_RED,255, 77, 111, "L");
ReefAngel.LCD.DrawText(COLOR_RED,255, 77, 121, "O");
ReefAngel.LCD.DrawText(COLOR_NAVY,255, 126, 109, "*");
ReefAngel.LCD.DrawText(COLOR_NAVY,255, 126, 121, "*");
ReefAngel.LCD.DrawText(COLOR_RED,255,14,40,"TANK");
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 10, 50, text, Num8x16);
ReefAngel.LCD.DrawText(COLOR_RED,255,99,40,"PH");
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 89, 50, text, Num8x16);
// Main Relay Box
ReefAngel.LCD.DrawOutletBox(12, 85, TempRelay);
ReefAngel.LCD.DrawText(COLOR_RED,255,14,63,"SUMP");
ConvertNumToString(text, ReefAngel.Params.Temp[T2_PROBE], 10);
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 10, 72, text, Num8x16);
ReefAngel.LCD.DrawText(COLOR_RED,255,92,63,"ROOM");
ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 92, 89, 72, text, Num8x16);
ReefAngel.LCD.DrawText(COLOR_RED,255,10,110, "White");
ReefAngel.LCD.DrawText(COLOR_BLUE,255, 32, 119, "%");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,12,119, ReefAngel.PWM.GetDaylightValue());
//ReefAngel.PWM.GetDaylightValue(),
ReefAngel.LCD.DrawText(COLOR_RED,255,90,110, "Blue");
ReefAngel.LCD.DrawText(COLOR_BLUE,255, 114, 119, "%");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,92,119, ReefAngel.PWM.GetActinicValue());
ReefAngel.LCD.FillCircle(57,122,3,COLOR_RED);
ReefAngel.LCD.FillCircle(57,122,3,COLOR_GREEN);
ReefAngel.LCD.FillCircle(70,122,3,COLOR_RED);
ReefAngel.LCD.FillCircle(70,122,3,COLOR_GREEN);
//ReefAngel.PWM.GetActinicValue());
//ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params,
bool atoSpanReached; //flag to determine if the controller has been running long enough to start ATO functionality
ReefAngel.PHMin=305;
ReefAngel.PHMax=995;
for (int a=0;a<SIZE(menu_items);a++)
ReefAngel.InitMenu(pgm_read_word(&(menu_items[a])),a);
ReefAngel.AddDateTimeMenu();
ReefAngel.FeedingModePorts = Port5Bit |Port6Bit;
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit;
ReefAngel.AddCustomColors();
InternalMemory.OverheatTemp_write( 790 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardATO(2, 120);
ReefAngel.StandardLights( Port1,11,25,17,15 );
ReefAngel.StandardLights( Port3,17,0,11,30 );
ReefAngel.WavemakerRandom1( Port5,15,45 );
ReefAngel.WavemakerRandom2( Port6,30,90 );
ReefAngel.StandardLights( Port7,13,0,15,30 );
if(ReefAngel.isWaterChangeMode()==1) Serial.println("In water change mode");
if(ReefAngel.isFeedingMode()==1) Serial.println("In feeding mode");
ReefAngel.LCD.BacklightOn();
ReefAngel.PWM.SetActinic( PWMSlope(11,30,17,0,11,50,60,0) );
DaylightPWMValue=PWMSlope(12,30,16,0,11,12,60,0);
CheckCloud();
ReefAngel.Portal( "CASPAR" );
int x,y;
// Parameters
// Main Relay Box
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 3
#define Start_Cloud_After NumMins(11,30)
#define End_Cloud_Before NumMins(18,30)
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen resul
// could happen.
// In our example, we have 510 minutes between Start_Cloud_After and End_Cloud_Before, so double the 250 minutes (or 500 minutes) can
// fit in that 510 minutes window.
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=10;
lightningchance=1;
cloudstart=NumMins(hour(),minute())+1;
if (cloudchance)
//is it time for cloud yet?
DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue,12,60);
ReefAngel.Relay.Off( Port8 );
if (lightningchance && (NumMins(hour(),minute())==(cloudstart+(cloudduration/2))) && second()<50)
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=85;
DaylightPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
ReefAngel.LCD.DrawText(COLOR_NAVY,255,4,16,"CL");
ReefAngel.LCD.DrawText(0,255,20,16,"00:00");
ReefAngel.LCD.DrawText(COLOR_NAVY,255,75,16,"Li");
ReefAngel.LCD.DrawText(0,255,95,16,"00:00");
ReefAngel.LCD.DrawText(COLOR_NAVY,255,44,30,"Duration");
int x=0;
if ((cloudstart/60)>=10) x=20;
else x=26;
ReefAngel.LCD.DrawText(COLOR_RED,255,x,16,(cloudstart/60));
if ((cloudstart%60)>=10) x=38;
else x=44;
ReefAngel.LCD.DrawText(COLOR_RED,255,x,16,(cloudstart%60));
ReefAngel.LCD.DrawText(COLOR_GREEN,255,62,40,cloudduration);
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=95;
else x=101;
ReefAngel.LCD.DrawText(COLOR_PURPLE,255,x,16,((cloudstart+(cloudduration/2))/60));
if (((cloudstart+(cloudduration/2))%60)>=10) x=113;
else x=119;
ReefAngel.LCD.DrawText(COLOR_PURPLE,255,x,16,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
ForceCloud=true;
void MenuEntry4()
void MenuEntry5()
void MenuEntry6()
byte x = 6;
byte y = 2;
byte t;
// Parameters
// Main Relay Box
CheckCloud();
int x,y;
// Parameters
// Main Relay Box
void CheckCloud()
// could happen.
#else
#endif
if (cloudchance)
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=10;
lightningchance=1;
if (cloudchance)
DaylightPWMValue=0;
delay(1);
cloudindex++;
int x=0;
else x=26;
else x=44;
int x=0;
else x=101;
else x=119;
cstart*=60;
cend*=60;
