Re: EDIT COLOR FILE?
Posted: Thu Jan 30, 2025 5:02 pm
by CASPAR
OK I TRIED AND I GET THE BELOW ERROR.....
Compilation failed for CASPAR.ino: Details: CASPAR.ino: In function 'void DrawCustomMain()': CASPAR.ino:117:1: error: 'DrawCustomOutletBox' was not declared in this scope CASPAR.ino:117:1: note: suggested alternative: 'DrawCustomGraph' CASPAR.ino: In function 'void loop()': CASPAR.ino:236:1: error: a function-definition is not allowed here before '{' token
BELOW HERE IS THE CODE I TRIED......
const char menu1_label[] PROGMEM = "Feeding Mode";
const char menu2_label[] PROGMEM = "Water Change Mode";
const char menu3_label[] PROGMEM = "Cloud On Demand";
const char menu4_label[] PROGMEM = "Clear ATO Timeout";
const char menu5_label[] PROGMEM = "Set Clock";
const char menu6_label[] PROGMEM = "Calibrate pH";
const char *const menu_items[] PROGMEM = {
menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label};
#define OutletOnBGColor COLOR_BLUE // Outlet On Background Color
#define OutletOnFGColor COLOR_BLACK // Outlet On Font Color
#define OutletOffBGColor COLOR_WHITE // Outlet Off Background Color
#define OutletOffFGColor COLOR_BLACK // Outlet Off Font Color
byte DaylightPWMValue=0;
boolean ForceCloud=false;
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ForceCloud=true;
ReefAngel.DisplayedMenu=RETURN_MAIN_MODE;
void MenuEntry4()
ReefAngel.ATOClear();
void MenuEntry5()
ReefAngel.SetupDateTime();
void MenuEntry6()
ReefAngel.SetupCalibratePH();
byte x = 6;
byte y = 2;
byte t;
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.Clear(COLOR_INDIGO, 1, 11, 132, 11);
ReefAngel.LCD.DrawText(COLOR_INDIGO,255, 1, 102, "----------------------");
ReefAngel.LCD.DrawText(COLOR_INDIGO,255, 1, 126, "----------------------");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,56,110, "ATO");
ReefAngel.LCD.DrawText(COLOR_NAVY,255, 2, 109, "*");
ReefAngel.LCD.DrawText(COLOR_NAVY,255, 2, 121, "*");
ReefAngel.LCD.DrawText(COLOR_RED,255, 45, 111, "H");
ReefAngel.LCD.DrawText(COLOR_RED,255, 45, 121, "I");
ReefAngel.LCD.DrawText(COLOR_RED,255, 77, 111, "L");
ReefAngel.LCD.DrawText(COLOR_RED,255, 77, 121, "O");
ReefAngel.LCD.DrawText(COLOR_NAVY,255, 126, 109, "*");
ReefAngel.LCD.DrawText(COLOR_NAVY,255, 126, 121, "*");
ReefAngel.LCD.DrawText(COLOR_RED,255,14,40,"TANK");
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 10, 50, text, Num8x16);
ReefAngel.LCD.DrawText(COLOR_RED,255,99,40,"PH");
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 89, 50, text, Num8x16);
DrawCustomOutletBox(12, 101, TempRelay);
ReefAngel.LCD.DrawText(COLOR_RED,255,14,63,"SUMP");
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 10, 72, text, Num8x16);
ReefAngel.LCD.DrawText(COLOR_RED,255,92,63,"ROOM");
ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 89, 72, text, Num8x16);
ReefAngel.LCD.DrawText(COLOR_RED,255,10,110, "White");
ReefAngel.LCD.DrawText(COLOR_BLUE,255, 32, 119, "%");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,12,119, ReefAngel.PWM.GetDaylightValue());
//ReefAngel.PWM.GetDaylightValue(),
ReefAngel.LCD.DrawText(COLOR_RED,255,90,110, "Blue");
ReefAngel.LCD.DrawText(COLOR_BLUE,255, 114, 119, "%");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,92,119, ReefAngel.PWM.GetActinicValue());
ReefAngel.LCD.FillCircle(57,122,3,COLOR_RED);
ReefAngel.LCD.FillCircle(57,122,3,COLOR_GREEN);
ReefAngel.LCD.FillCircle(70,122,3,COLOR_RED);
ReefAngel.LCD.FillCircle(70,122,3,COLOR_GREEN);
//ReefAngel.PWM.GetActinicValue());
//ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params,
bool atoSpanReached; //flag to determine if the controller has been running long enough to start ATO functionality
ReefAngel.PHMin=305;
ReefAngel.PHMax=995;
for (int a=0;a<SIZE(menu_items);a++)
ReefAngel.InitMenu(pgm_read_word(&(menu_items[a])),a);
ReefAngel.AddDateTimeMenu();
ReefAngel.FeedingModePorts = Port5Bit |Port6Bit;
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit;
ReefAngel.AddCustomColors();
InternalMemory.OverheatTemp_write( 790 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardATO(2, 120);
ReefAngel.StandardLights( Port1,11,25,17,15 );
ReefAngel.StandardLights( Port3,17,0,11,30 );
ReefAngel.WavemakerRandom1( Port5,15,45 );
ReefAngel.WavemakerRandom2( Port6,30,90 );
ReefAngel.StandardLights( Port7,13,0,15,30 );
if(ReefAngel.isWaterChangeMode()==1) Serial.println("In water change mode");
if(ReefAngel.isFeedingMode()==1) Serial.println("In feeding mode");
ReefAngel.LCD.BacklightOn();
ReefAngel.PWM.SetActinic( PWMSlope(11,30,17,0,11,50,60,0) );
DaylightPWMValue=PWMSlope(12,30,16,0,11,12,60,0);
CheckCloud();
void DrawCustomOutletBox(byte x, byte y,byte RelayData)
ReefAngel.LCD.Clear(OutletBorderColor,x,y,x+104,y); //94
ReefAngel.LCD.Clear(OutletBorderColor,x,y+12,x+104,y+12);
for (byte a=0;a<8;a++)
byte bcolor = OutletOffBGColor;
byte fcolor = OutletOffFGColor;
char temp[]=" ";
if ((RelayData&(1<<a))==1<<a)
bcolor = OutletOnBGColor;
fcolor = OutletOnFGColor;
ReefAngel.LCD.Clear(bcolor,x+(a*13),y+1,x+13+(a*13),y+11);
itoa(a+1,temp,10);
ReefAngel.LCD.DrawText(fcolor,bcolor,x+4+(a*13),y+3,temp);
ReefAngel.Portal( "CASPAR" );
int x,y;
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 3
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen resul
// could happen.
// In our example, we have 510 minutes between Start_Cloud_After and End_Cloud_Before, so double the 250 minutes (or 500 minutes) can
// fit in that 510 minutes window.
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=10;
lightningchance=1;
cloudstart=NumMins(hour(),minute())+1;
if (cloudchance)
//is it time for cloud yet?
DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue,12,60);
ReefAngel.Relay.Off( Port8 );
if (lightningchance && (NumMins(hour(),minute())==(cloudstart+(cloudduration/2))) && second()<50)
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=85;
DaylightPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
ReefAngel.LCD.DrawText(COLOR_NAVY,255,4,16,"CL");
ReefAngel.LCD.DrawText(0,255,20,16,"00:00");
ReefAngel.LCD.DrawText(COLOR_NAVY,255,75,16,"Li");
ReefAngel.LCD.DrawText(0,255,95,16,"00:00");
ReefAngel.LCD.DrawText(COLOR_NAVY,255,44,30,"Duration");
int x=0;
if ((cloudstart/60)>=10) x=20;
else x=26;
ReefAngel.LCD.DrawText(COLOR_RED,255,x,16,(cloudstart/60));
if ((cloudstart%60)>=10) x=38;
else x=44;
ReefAngel.LCD.DrawText(COLOR_RED,255,x,16,(cloudstart%60));
ReefAngel.LCD.DrawText(COLOR_GREEN,255,62,40,cloudduration);
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=95;
else x=101;
ReefAngel.LCD.DrawText(COLOR_PURPLE,255,x,16,((cloudstart+(cloudduration/2))/60));
if (((cloudstart+(cloudduration/2))%60)>=10) x=113;
else x=119;
ReefAngel.LCD.DrawText(COLOR_PURPLE,255,x,16,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
