UAPP PROBLEMS
Posted: Thu Apr 02, 2026 11:27 am
by CASPAR
AS OF YESTERDAY MORNING MY UAPP HAS STOPPED REFRESHING, ANY IDEAS ANYONE?
Re: UAPP PROBLEMS
Posted: Thu Apr 02, 2026 11:30 am
by brennyn21
Do you get an error? Can you try logging out and back in again?
Re: UAPP PROBLEMS
Posted: Thu Apr 02, 2026 11:41 am
by CASPAR
YES HAVE LOGGED OUT THEN BACK ON AND STILL GET ERROR "FAILED TO REFRESH DATA"
THIS LINE I MADE SURE IS IN MY CODE "ReefAngel.Portal( "CASPAR" );"
Re: UAPP PROBLEMS
Posted: Thu Apr 02, 2026 11:45 am
by CASPAR
UAPP ON PHONE AND COMPUTER DOES NOT REFRESH BUT THE OLD APP ON MY PHONE DOES IN BOTH HOME AND AWAY MODE
Re: UAPP PROBLEMS
Posted: Thu Apr 02, 2026 11:46 am
by brennyn21
Did your router or port forwarding change? Can you access your controller by going to your publicIP:2000?
Re: UAPP PROBLEMS
Posted: Thu Apr 02, 2026 11:51 am
by CASPAR
IF I PUT MY IP IN I JUST GET Reef Angel Controller Web Server
Re: UAPP PROBLEMS
Posted: Thu Apr 02, 2026 12:00 pm
by CASPAR
ALSO JUST GOT EMAIL NOTIFICATION ABOUT 10 MINUTES AGO THAT SAID REEF ANGEL HAS RE ESTABLISHED CONNECTION, BUT STILL DOESNT WORK
Re: UAPP PROBLEMS
Posted: Thu Apr 02, 2026 12:06 pm
by brennyn21
If you can see the webserver, then it should be working, does it let you change the modes or turn on or off an outlet?
Re: UAPP PROBLEMS
Posted: Thu Apr 02, 2026 12:21 pm
by CASPAR
I DONT SEE NOTHING BUT THE WORDS REEF ANGEL CONTROL WEB SERVER NOTHING ELSE.
FAR AS CHANGING STATUS OF THE RELAY IT WILL NOT DO THAT EITHER JUST SAYS SOMETHING TO THE EFFECT OF FAILED TO UPDATE COMMAND AT BOTTOM OF SCREEN IN RED
Re: UAPP PROBLEMS
Posted: Thu Apr 02, 2026 12:39 pm
by brennyn21
Can you try deleting the controller and then readding it?
Re: UAPP PROBLEMS
Posted: Thu Apr 02, 2026 12:45 pm
by CASPAR
THAT DID IT, WHAT MAY HAVE CAUSED THIS?
Re: UAPP PROBLEMS
Posted: Thu Apr 02, 2026 1:00 pm
by CASPAR
BRENNY21 I SENT YOU A PM....
Re: UAPP PROBLEMS
Posted: Thu Apr 02, 2026 1:13 pm
by brennyn21
I wonder if your IP changed and the Uapp didn't update correctly I will do some investigating. I responded to your PM
Re: UAPP PROBLEMS
Posted: Thu Apr 02, 2026 1:31 pm
by CASPAR
MORE THAN LIKELY IP MAY HAVE CHANGED DUE TO SPECTRUM DOING AN OVERNIGHT MAINTENACE THING, AND TRUST ME IT SCREWED UP ALOT OF CRAP!!!
