Upload Times Out
Posted: Mon Aug 31, 2026 12:55 am
by madmarks
I just re-worked my system, I am now putting in two Reef Angel + to create redundancy. I long time ago I had a tank crash when a breaker flipped during a brown out and have wanted to do a redundant system for quite some time. I haven't touched a controller in years (they just work).
I just discovered the Webwizard. I redid the settings for the 1st controller and it complied fine. However, when I went to upload the code, it caused the unit to constantly cycle/reset every 1 or 2 seconds and I had continuous time out errors in the Webwizard. I notice the baud rate was autoset to 115200, I believe this maybe the issue.
1) Has anyone experienced a similar problem?
2) Is there a way to lower the baud?
Thanks in advance.
Re: Upload Times Out
Posted: Mon Aug 31, 2026 12:57 am
by brennyn21
Let me take a look i just uploaded code to an RAPlus last week, do you have a copy of the log from the cmd line?
Posted: Mon Aug 31, 2026 1:00 am
by madmarks
I can get one tomorrow. It is a tad late, I am on Eastern time. I will upload then.
Posted: Mon Aug 31, 2026 1:24 am
by brennyn21
Sounds good I'll check server logs I did push an update, but nothing that should affect upload. Also make sure you are using the latest wizard plugin.
Posted: Mon Aug 31, 2026 2:13 pm
by madmarks
ok this what I am seeing:
, both from a MAC and Windows 10 device. I have tried two different cables.
Posted: Mon Aug 31, 2026 2:14 pm
by madmarks
The plugins were downloaded yesterday.
Posted: Mon Aug 31, 2026 2:21 pm
by brennyn21
Does the Plus respond at all like flash the red light or anything when you try to upload?
Posted: Mon Aug 31, 2026 5:23 pm
by madmarks
Yes it does. About every 1 - 2 seconds the red light flashes and the system goes dark, the relay box clicks. Then the system comes back and the cycle repeats. It seems to correspond to the time out message.
Posted: Mon Aug 31, 2026 5:27 pm
by brennyn21
For some reason the bootloader isn't responding, are you using the original usb ttl cable?
Posted: Mon Aug 31, 2026 6:28 pm
by madmarks
I just figured it out. It has been so long. I, stupidly, was left orientating the connector, with the green wire to the left most pin, instead of right orientating the connector with the green wire to the 3rd pin. It loaded fine when I shifted the connector to the right. I built my own in house app, that functions like a local Uapp, it has confirmed the change in config.
Posted: Mon Aug 31, 2026 6:35 pm
by madmarks
if you hadn't asked about the cables, I would never had looked at the orientation. I appreciate the help.
Posted: Mon Aug 31, 2026 7:14 pm
by brennyn21
Glad you got it working!
