Power Cycling for WIFI
mineman@mac.com
Post by mineman@mac.com »
I keep loosing connection from my iPhone app every night until I power cycle the controller; then everything works great for 24 hours. I tried everything in this thread http://forum.reefangel.com/viewtopic.ph ... wifi#p4708 to the best of my ability but no dice (keep in mind that I am BARELY beginning to understand this thing) :?. This is the code I am using
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
  ReefAngel.SingleATOLow(Port1);
  ReefAngel.StandardLights(Port2,14,30,20,30); // Turn Port 2 on at 14:30 and off at 20:30
  ReefAngel.StandardLights(Port3,14,0,21,0); // Turn Port 3 on at 14:00 and off at 21:00
  ReefAngel.StandardLights(Port4,13,30,21,30); // Turn Port 4 on at 14:00 and off at 21:00
  ReefAngel.Wavemaker1(Port5);
  ReefAngel.Wavemaker2(Port6);
  if (now()%43200<6) ReefAngel.Relay.On(Port8);
  else ReefAngel.Relay.Off(Port8);
  // You can only increment the dosing in seconds
  // 43200 the frequency in seconds that the dosing pump will be activated. 24hrs= 86400s, 12hrs= 43200s
  // 6 is the number of seconds that the dosing pump will stay on.
  if (bitRead(ReefAngel.Relay.RelayData,3)==0)
Any help would be appreciated!
wolfador
Re: Power Cycling for WIFI
Post by wolfador »
What are the lights on the wifi adapter doing when you are unable to connect? I have had it stop working a time or two where the amber light stayed light, however just unplugging / replugging the wifi adapter back in fixed it.
John
