Retrieve code installed on controller
Posted: Fri Feb 17, 2012 1:38 am
by Aricml
If you were toying with code and accidentally made it unable to compile on your PC, but still have a workable version on your RA, is it possible to extract the .ino from the controller itself? If so, how?
Re: Retrieve code installed on controller
Posted: Fri Feb 17, 2012 5:07 am
by wolfador
Thats a good question, in my non-expert opinion I would think not since when it is uploaded it is compiled and you would have to re-download and decompile it which is very complicated to do.
Posted: Fri Feb 17, 2012 12:10 pm
by binder
Correct. You are not able to retrieve the code for the reasons wolfador mentioned.
Posted: Fri Feb 17, 2012 8:41 pm
by wolfador
In the future you can setup a github account and have your .ino's synced to there. That way you have access to pretty much every change you ever make.
