Timers
Posted: Fri Feb 17, 2012 10:03 pm
by jsclownfish
In the new code for wavemakers how do would I display the timers. I was using this before...
int t=ReefAngel.Timer[1].Trigger-now();
if (t>=0)
ReefAngel.LCD.Clear(255,105,33,135,43);
ReefAngel.LCD.DrawText(0, DefaultBGColor,105,33,t);
It looks like I would use ReefAngel.WMRTimer.Trigger-now(), but that isn't recognized. I am still using the same code above for the side to side powerheads, but I am adding a few more smaller ones on the back wall to increase flow in other directions. I am using random times and the new function to direct them, but it would be nice to display the times as well on those powerheads.
Jon
Re: Timers
Posted: Sat Feb 18, 2012 7:02 am
by binder
if you are using the standard Wavemaker function, here is the code for determination of the timer:
Actually, this is just the condition that determines when to toggle the port inside the Wavemaker function
In order to determine how many seconds are left, you would need to do something like this:
// WMTimer is the value for the wavemaker
// put in whatever value you use for your wavemakers
int t = WMTimer - (now()%(WMTimer*2));
// if you are using wavemaker one, it can be this:
int t = InternalMemory.WM1Timer_read() - (now()%(InternalMemory.WM1Timer_read()*2));
What you want to do is compute the same time that the function computes and then subtract that value from the value of the timer. We may be able to simplify things a little and create a function for you to call.
Then you can use your existing code to display it on the screen.
If you are using the WavemakerRandom functions, then you will not be able to display the remaining time.
Re: Timers
Posted: Wed Mar 07, 2012 11:34 am
by jsclownfish
Hmm. I have large "wavemaker" powerheads on the sides of the tank and I wanted to add a couple more smaller ones to help in dead spots around the rock. I tried this to control them...
// Wavemaker Code with night option
if (ReefAngel.Timer[1].IsTriggered() )
if ((hour() >= 21) || (hour() <= 8)) //from 9p-Midnight
{ //PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM,
// byte endPWM, byte Duration, byte oldValue)
wmpulse=PWMSlope(21,0,8,0,5,30,179,30);
if (wmdelay)
ReefAngel.Timer[1].SetInterval(wmpulse); // WM delay function from 30-170 sec.
ReefAngel.Timer[1].Start();
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
if (wmport==Port5) wmport=Port6; else wmport=Port5;
wmdelay=false;
ReefAngel.Timer[1].SetInterval(200-wmpulse); // WM bursts timing from 170-30 sec.
ReefAngel.Relay.On(wmport);
wmdelay=true;
//8a-10p normal wave settings
ReefAngel.Timer[1].SetInterval(InternalMemory.WM1Timer_read());
//extra small powerheads to increase circulation
if (ReefAngel.Timer[5].IsTriggered())
ReefAngel.Timer[5].SetInterval(random(15,90));
ReefAngel.Timer[5].Start();
ReefAngel.Relay.Toggle(Box1_Port5);
ReefAngel.Relay.Toggle(Box1_Port6);
and the pumps seem to work OK, and I could display the two different timers, but the random one is not accurate. I guess that is because it runs the random timing function after the trigger is set. Maybe I could assign the random # to a variable and have it cound down from that # somehow?
Re: Timers
Posted: Wed Mar 07, 2012 11:56 am
by binder
Correct. The random one will not show properly. You are also correct with storing the value. Instead of doing this:
You could do this:
wt = random(15,90);
ReefAngel.Timer[5].SetInterval(wt);
Then you would have to add this:
outside of the loop() (up by the other global variables) and you could use wt as the value to count down from.
Re: Timers
Posted: Tue Mar 13, 2012 2:47 pm
by jsclownfish
I tried this...
wmaker2=random(15,90);
ReefAngel.Timer[5].SetInterval(wmaker2);
but the interval was much larger than 90 seconds (>1000). Does the random function like this change the units from seconds to minutes or something?
Jon
Re: Timers
Posted: Tue Mar 13, 2012 4:13 pm
You missed the start of the timer again.
Re: Timers
Posted: Tue Mar 13, 2012 4:16 pm
Oh, one other note....
Timer[5] is used by the controller to control the writing to memory of parameters that draw the graphs on the screen.
Timers 1 and 2 are free to use if you are not using them for dosing pumps.
Re: Timers
Posted: Tue Mar 13, 2012 4:34 pm
by jsclownfish
OK, thanks. I'll try it tonight. BTW, does the RA+ have more timer options? I am currently only want to use two for the four wavemakers, but at some point I also want to install the dosing pump. I seem to remember more were available on the 2560.
Also, are the parameters for the graphs always written to memory and written over as needed? I was thinking about graphing one of the flow meters over time or graphing making the graph on the remote monitor, but I wasn't sure how it was done.
-Jon
Re: Timers
Posted: Tue Mar 13, 2012 5:28 pm
Oh, you can define your own timers.
Put this about setup():
Then you can use it just like you've done with the other timers:
MyTimer.SetInterval(100);
MyTimer.Start();
The parameters are always stored in the memory no matter what.
Re: Timers
Posted: Thu Apr 26, 2012 2:19 pm
by jsclownfish
I'm a little confused about Timers and libraries v0.9.x. If I want Dosing pumps, 2 wavemaker timers, and ATO, which should I be using. Now that the dosing pumps aren't using timers, which ones are available? Or should I just define my own as you suggested above?
Jon
Re: Timers
Posted: Thu Apr 26, 2012 3:30 pm
Wavemaker are not using timers anymore.
ATO never used a timer.
There are 2 types of Dosing pump functions: DosingPumpRepeat doesn't use timers anymore and DosingPump, which is the only remaining one that uses timers.
But feel free to create your own timers. This way, you know for sure they are being exclusevily being used by your function.
Re: Timers
Posted: Sat Apr 28, 2012 2:46 pm
by binder
If you use the Timers, you can do a "countdown" or keep track of the remaining time easier. There's a little more work involved to get the time remaining if you don't use the timers. The upside though is decreased code size from not using the Timers.
