My RA is on my 14g biocube with retrofitted leds from Modularled. I have my whites and blues on two separate drivers. My whites are on a meanwell that is dimmed through PWM. I am successfully controlling my leds with the controller and simulating clouds and T-storms.
The first thing I would like to add is the code for a single low ATO. I have ordered the ATO kit from AVAST marine with the RA connection. I know I need to add the following line of code, but do not understand all the functions.
ReefAngel.SingleATO(true, Port1, 60, 1);
Could someone tell me what all the options do?
In the future I would like to make a custom main and menu system, but I would like to get the small things working first.
Below is my current PDE.
// Autogenerated file by RAGen (v1.1.0.126), (01/30/2012 21:35)
// RA_013012_2135.pde
#define MetalHalideSetup
#define DisplayLEDPWM
#define wifi
#define StandardLightSetup
#define WDT
#define PWMEXPANSION
#include <ReefAngel_Colors.h>
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
//Give labels to outlets for easier programming
#define Fan 8
#define Sump 7
#define Heater 6
#define Vortech 5
#define Return 4
#define Skimmer 3
#define BlueLED 2
#define WhiteLED 1
byte DaylightPWMValue=0;
ReefAngel.FeedingModePorts = B00010000;
ReefAngel.WaterChangePorts = B00011100;
ReefAngel.OverheatShutoffPorts = B00000011;
ReefAngel.LightsOnPorts = B00000011;
ReefAngel.Relay.On(Skimmer);
ReefAngel.Relay.On(Return);
ReefAngel.Relay.On(Vortech);
ReefAngel.Relay.On(Fan);
// Specific functions
ReefAngel.MHLights(WhiteLED);
ReefAngel.StandardLights(BlueLED);
ReefAngel.StandardHeater(Heater);
DaylightPWMValue=PWMSlope(12,00,20,00,13,40,200,DaylightPWMValue);
//ReefAngel.PWM.SetActinic(MoonPhase());
//DaylightPWMValue=100;
CheckCloud();
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 5
#define Max_Cloud_Duration 20
#define Min_Clouds_per_Day 0
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(00,00)
#define End_Cloud_Before NumMins(23,59)
#define Lightning_Change_per_Cloud 50
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
if (lightningchance && (NumMins(hour(),minute())==(cloudstart+(cloudduration/2))) && second()<10)
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
int x=0;
if (lightningchance)
int x=0;
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
