Problem with Reef Angel - Screen or Controller
Posted: Mon Feb 27, 2012 2:24 pm
by Paride0475
Hi,
I have some problems with the screen or controller of ReefAngel. Following some pictures:
I tried changing pde and reload it ... reboot the device several times .... disconnect and reconnect temperature sensors....but nothing to be done each time a different problem makes it unusable ...
What happened? any suggestions?
Thanks Paride
Re: Problem with Reef Angel - Screen or Controller
Posted: Mon Feb 27, 2012 2:33 pm
Do you have problems when you have no temperature probes connected too?
Posted: Mon Feb 27, 2012 2:38 pm
by Paride0475
When the temperature probes aren't connect the screen appears as in Figure 2012-02-27 22.12.48.jpg (Temp 0.0, Canopy Temp Error, Ambient Temp Error)
Posted: Mon Feb 27, 2012 2:40 pm
Actually, can you reboot the controller while there is no probes connected and let me know if there is any problems?
Posted: Mon Feb 27, 2012 2:46 pm
by Paride0475
I reboot without probes connected. The screen remains as previously described in Figure 2012-02-27 22.12.48.jpg
Posted: Mon Feb 27, 2012 3:03 pm
There is nothing wrong on that picture.
Now, plug one probe and reboot.
What happens?
Posted: Mon Feb 27, 2012 3:26 pm
by Paride0475
I reboot with one probe connected. After few seconds some noise from relay box and the screen appear like in figure 1.
Posted: Mon Feb 27, 2012 3:32 pm
Does it do the same thing if you use a diffrerent probe too?
Posted: Mon Feb 27, 2012 3:34 pm
by Paride0475
Yes, I use different probes and I try to connect in different connectors. :-(
Posted: Mon Feb 27, 2012 3:35 pm
can i see your code?
Posted: Mon Feb 27, 2012 3:57 pm
by Paride0475
sure...this is the last version. I'm working on it to simplify because I think the problem could be in the pde
sketch_feb26h.pde
Posted: Mon Feb 27, 2012 4:02 pm
Try changing this:
  char text[7];
To this:
Does it make any difference?
Posted: Mon Feb 27, 2012 4:14 pm
by Paride0475
something should be changed...
Temp 1 seems to be working properly. The visualization is correct.
I switch off, connect the second probe, switch on...Temp 2 is "-2027.-"
Posted: Mon Feb 27, 2012 4:20 pm
by Paride0475
after a reboot the problem has reappeared even on temp 1
:cry:
Posted: Mon Feb 27, 2012 4:51 pm
Has it worked in the past?
Does this problem also happen with a simple code on the standard main screen?
Try loading this:
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_Wifi.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#include <ReefAngel_Colors.h>
Does it do the same thing?
Posted: Tue Feb 28, 2012 1:06 pm
by Paride0475
the system has always had some little problem, but I always thought of a programming error code.
a similar problem with preloaded code. Some strange number on the screen in correspondence to temperature. Following the pics:
now I try with your last code.
Posted: Tue Feb 28, 2012 1:23 pm
Does it happen right away when you boot up the controller?
Posted: Tue Feb 28, 2012 1:24 pm
by Paride0475
Unfortunately the problem remains:
Posted: Tue Feb 28, 2012 1:28 pm
You got a pm
