PH Calibration
Posted: Tue Feb 28, 2012 7:36 pm
by Zechenia
Quick question. If I calibrate the PH probe, and then update the code on my controller (for say... WIFI here in a couple months :D) would I need to recalibrate, or would it save the settings?
Re: PH Calibration
Posted: Tue Feb 28, 2012 8:01 pm
by binder
It should save the settings. The settings are stored in the internal memory. The only way it would change is if you were to reload the Internal Memory values from the INO/PDE file OR if you were to change the internal memory value from one of the apps.
Re: PH Calibration
Posted: Tue Feb 28, 2012 8:02 pm
by rossbryant1956
Should be mutually exclusive. Should not matter at all.
Re: PH Calibration
Posted: Tue Feb 28, 2012 8:22 pm
by Zechenia
Perfect! Thanks!
Re: PH Calibration
Posted: Tue Feb 28, 2012 9:30 pm
by rossbryant1956
binder wrote:OR if you were to change the internal memory value from one of the apps.
Are you saying I can change this from inside the client app? I have been wanting to do this but been too lazy to change and reload my memory file. Thx
Re: PH Calibration
Posted: Wed Feb 29, 2012 5:36 am
by binder
I'm not sure about the client app. I know you can from the android app and java status app.
Re: PH Calibration
Posted: Wed Feb 29, 2012 10:13 am
by dmolton
Sure can. Bottom right hand side of the Memory tab:
