ok, i will post a series of code,
Posted: Wed Feb 29, 2012 10:03 am
here is my first RAgen 'main relay set up'. I will be running my koralia nanos and maxijet all the time with feed mode and water change mode set to turn them off. they are not controllable. what i intended with the code.
Port 1 - power for White LED channel on duo 700 driver (will be controled analog 0-10v when i figure it out)
Port 2 - power for Blue LED channel on duo 700 driver (will be controled analog 0-10v when i figure it out)
Port 3 - power for fan built into led lights to cool them.(turn on/off based on LED on/off when i figure it out)
LED ports should allways be on b/c the analog signal will read 0v when off. is there any reason to have Port 1 and 2 turn off when the analog signal is at 0v?
Port 4 - power for the heater. (would like to use heater thermometer and have a safety off at temp>= 83F when i figure it out)
Port 5 - ATO intended to have a high and high/high set up
Port 6 - Koralia Nano
Port 7 - Koralia Nano
Port 8 - Maxijet 900
here is the code
how does this look
my controller was ordered and I am waiting for it to arrive. I also ordered the wifi attachment.
thanks
here is the code
// Autogenerated file by RAGen (v1.2.1.158), (02/29/2012 10:53)
// RA_022912_1053.ino
#define DisplayImages
#define DateTimeSetup
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define SIMPLE_MENU
#define PWMEXPANSION
#define ENABLE_ATO_LOGGING
ReefAngel.FeedingModePorts = Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.On(Port8);
// Specific functions
ReefAngel.StandardLights(Port1);
ReefAngel.StandardFan(Port3);
ReefAngel.StandardHeater(Port4);
ReefAngel.StandardATO(Port5);
ReefAngel.Portal("miked");
thanks
