code for ATO using 2 floats high and high/high backup?
Posted: Wed Feb 29, 2012 3:06 pm
I have seen various codes for ATO but not for what I am wanting. I would like to have both floats with wires up. one mounted to trigger ATO port on when water/float is down and port off when water/float is up. I would like to have the second float higher and be a backup so no port control when float is down and port off when float is up. having the high/high notify me when it is activated.
Thanks for pointing me in the correct direction.
