Need help with an error code
Posted: Thu Mar 01, 2012 8:24 pm
by dangrymidget
I've been reading through the forums figuring out my code, when i tried to upload it I got a " no matching function for call to 'ReefAngelClass::SingleATOLow(int, int)'"
here's my code:
  ReefAngel.Relay.On(Port8); //Turn Port8 on at startup
  ReefAngel.PWM.SetDaylight(0);  //Set pwm daylight channel to 0%
  ReefAngel.SingleATOLow(Port1,60);  //Setup Port1 as Auto Top-Off function with on/off
      if (ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Port1); //upper float set as shut off fail safe
  ReefAngel.StandardLights(Port2,22,30,8,0);  //Moonlight schedule 10:30pm - 8:00am
  ReefAngel.StandardLights(Port3,20,00,10,00);  //Refugium schedule 8:00pm - 10:00am
  ReefAngel.StandardHeater(Port6,780,785);  // Setup Heater to turn on at 78.0F and off at 78.5F
  ReefAngel.StandardFan(Port7,790,785);  // Setup Chiller to turn on at 79.0F and off at 78.5F
  ReefAngel.ShowInterface(); // Draws the standard graphical user interface}
  ReefAngel.PWM.SetDaylight(PWMSlope(9,30,21,30,0,25,60,0) //lights on at 9:00am off at 9:00pm from 0% to 100% over 120 min
Would appreciate it if someone could tell me what my problem is. I also want to know if i have my first light coded right, I want it to power on at 9:00 at 0% and start the dimming cycle at 9:30
Re: Need help with an error code
Posted: Thu Mar 01, 2012 9:03 pm
The error is because you are trying to do too much with the SingleATOLow function. You are trying to give it a timeout value and it does not need one. It uses the timeout value that is in the Internal Memory. So, you need to change your function to this:
ReefAngel.SingleATOLow(Port1);
As for your second question, if you are referring to the PWM slope function, then you are off a little. You are missing some stuff to make it work properly.
Use this instead:
  ReefAngel.SingleATOLow(Port1);  //Setup Port1 as Auto Top-Off function with on/off
  ReefAngel.StandardLights(Port3,20,0,10,0);  //Refugium schedule 8:00pm - 10:00am
  ReefAngel.PWM.SetDaylight(PWMSlope(9,0,21,0,0,100,120,0)); //lights on at 9:00am off at 9:00pm from 0% to 100% over 120 min
That will set your PWM function to match what you put in the comment about it.
Posted: Fri Mar 02, 2012 4:09 pm
by dangrymidget
Awesome thanks for the help!
Posted: Fri Mar 02, 2012 5:20 pm
by dangrymidget
I'm also trying to set my Moonlights on a 28 day cycle, but i have no idea where to start. can you point me in the right direction.
Posted: Sat Mar 03, 2012 9:35 am
dangrymidget wrote:I'm also trying to set my Moonlights on a 28 day cycle, but i have no idea where to start. can you point me in the right direction.
Sure can. Start here and read through this...
http://forum.reefangel.com/viewtopic.ph ... tPWM#p1099
You can also start searching on here for Moonlight, Moonphase, or Moonlightpwm
Posted: Sat Mar 03, 2012 10:36 am
Use this on your loop:
Posted: Sat Mar 03, 2012 11:00 pm
by dangrymidget
I read through the forum you linked and have a few questions: i'm not sure where to put the byte MoonPhase() code, when i put in i keep getting already defined errors. the other problem i'm having is with the PWM module, i want to hook my 2 moonlights up but i'm getting a not declared error. here's my code so far
  ReefAngel.PWM.SetActinic(PWMSlope(9,30,21,30,0,25,60,0)); //lights on at 9:30am off at 9:30pm from 0% to 25% over 60 min
  ReefAngel.PWM.SetDaylight(PWMSlope(9,30,21,30,0,25,60,0)); //lights on at 9:30am off at 9:30pm from 0% to 25% over 60 min
  PWMChannel[LEDPWM1]=MoonPhase();
  PWMChannel[LEDPWM2]=MoonPhase();
Posted: Sat Mar 03, 2012 11:06 pm
Let me just understand what you have.
You have an led driver connected to actinic PWM port and one driver connected to daylight PWM port, correct?
Then, you also have the PWM expansion module, right?
And you are trying to connect 2 dimmable moonlights on channels 0 and 1 of the PWM expansion module, is that correct?
Posted: Sun Mar 04, 2012 8:20 am
by dangrymidget
yes, i have the eagle files for the module but again not sure where to put them
Posted: Sun Mar 04, 2012 8:46 am
Use this then:
  ReefAngel.PWM.SetChannel(0,MoonPhase());
  ReefAngel.PWM.SetChannel(1,MoonPhase());
Then, you will connect the dimmable moonlights to channel 0 and 1.
Posted: Sun Mar 04, 2012 2:51 pm
by dangrymidget
I'm getting a code to big error with this code, how do i shrink it? at 32562 of 322256 bytes
Posted: Sun Mar 04, 2012 3:05 pm
Try using the simple menu
Posted: Sun Mar 04, 2012 6:29 pm
by dangrymidget
Awesome, got it working. Thanks for the help!
