Relay Expansion in Webbanner and Portal
Posted: Fri Mar 02, 2012 10:46 pm
by javisaman
Hmm, I don't know why I'm having so much trouble with this. But I was wondering how to get either the web banner or reef angel portal to display the statuses of all the relays (not just the main ones). I'm not using RAGen, but a custom INC.
Re: Relay Expansion in Webbanner and Portal
Posted: Fri Mar 02, 2012 11:11 pm
Can I see your code?
Posted: Sat Mar 03, 2012 6:32 am
by javisaman
//@author Javed Aman
//Custom Reef Angel Code
//dev libs
//#include <ReefAngel_Globals.h>
//#include <ReefAngel_Wifi.h>
//#include <ReefAngel_EEPROM.h>
//#include <ReefAngel_NokiaLCD.h>
//#include <ReefAngel_ATO.h>
//#include <ReefAngel_Joystick.h>
//#include <ReefAngel_LED.h>
//#include <ReefAngel_TempSensor.h>
//#include <ReefAngel_Relay.h>
//#include <ReefAngel_PWM.h>
//#include <ReefAngel_Timer.h>
//#include <ReefAngel_Memory.h>
#define WhiteLED 1
#define BlueLED 2
#define FugeLight 3
#define Vortech 4
#ifdef RelayExp
#define ATO 5
#else
#define KoraliaTank 5
#endif
#define Return 6
#define Heater 7
#define Chiller 8
#ifdef RelayExp
#define KoraliaTank 11
#define KoraliaFuge 12
#define Skimmer 14
#define LiterMeter 13
#define FluvalReturn 15
#define FluvalLights 16
#define SkimmerFlush 17
//#define Feeder 15
//#define WaterChangePump 16
//#define WaterChangeHeat 17
#endif
//ReefAngel_TimerClass ParamTimer;
void setup(){
ReefAngel.Init();
ReefAngel.Relay.On(Return);
ReefAngel.Relay.On(Vortech);
//ReefAngel.Relay.On(FugeLight);
//ReefAngel.Relay.On(WhiteLED);
//ReefAngel.Relay.On(BlueLED);
#ifdef RelayExp
ReefAngel.Relay.On(LiterMeter);
ReefAngel.Relay.On(Skimmer);
//ReefAngel.Relay.On(ATO);
ReefAngel.Relay.On(KoraliaFuge);
ReefAngel.Relay.On(FluvalReturn);
//ReefAngel.Relay.On(SkimmerFlush);
#endif
//ReefAngel.StandardATO(ATO, 5);
//ReefAngel.Relay.Off(ATO);
ReefAngel.Relay.On(KoraliaTank);
ReefAngel.FeedingModePorts = B00110000;
ReefAngel.WaterChangePorts = B11111000;
ReefAngel.OverheatShutoffPorts = B01000011;
#ifdef RelayExp
ReefAngel.FeedingModePortsE[0] = B00000001;
ReefAngel.WaterChangePortsE[0] = B00000111;
#endif
// Initialize and start the Parameter timer
// ParamTimer.SetInterval(15); // set interval to 15 seconds
// ParamTimer.Start();
void loop() {
ReefAngel.SingleATO(true, ATO, 10, 0);
ReefAngel.StandardLights(WhiteLED, 14, 25, 20, 35);
ReefAngel.PWM.SetDaylight(PWMSlope(14,30, 20,30, 0, 50, 80, ReefAngel.PWM.GetDaylightValue()));
//ReefAngel.PWM.SetDaylight(25);
ReefAngel.StandardLights(BlueLED, 10, 25, 21, 35);
ReefAngel.PWM.SetActinic(PWMSlope(10, 30, 21, 30, 0, 100, 120, ReefAngel.PWM.GetActinicValue()));
//ReefAngel.PWM.SetActinic(90);
ReefAngel.StandardLights(FluvalLights, 8, 25, 21, 35);
ReefAngel.StandardLights(SkimmerFlush, 21, 50, 21, 52);
ReefAngel.StandardLights(FugeLight, 19, 30, 11, 30);
ReefAngel.StandardHeater(Heater, 790, 800);
ReefAngel.StandardFan(Chiller, 800, 805);
ReefAngel.Relay.DelayedOn(Vortech, 2);
ReefAngel.Relay.DelayedOn(KoraliaTank, 2);
ReefAngel.Relay.DelayedOn(Skimmer, 10);
ReefAngel.Portal("javisaman");
void DrawCustomMain(){
ReefAngel.LCD.DrawDate(6, 119);
ReefAngel.LCD.DrawMonitor(15, 63, ReefAngel.Params,
// ReefAngel.PWM.DaylightPWMValue, ReefAngel.PWM.ActinicPWMValue); //standard
ReefAngel.PWM.GetDaylightValue(), ReefAngel.PWM.GetActinicValue()); //development
TempRelay != ReefAngel.Relay.RelayMaskOn;
#ifdef RelayExp
TempRelay != ReefAngel.Relay.RelayMaskOnE[0];
ReefAngel.LCD.DrawOutletBox(12, 105, TempRelay);
#endif RelayExp
void DrawCustomGraph(){
Posted: Sat Mar 03, 2012 9:20 am
Are you sure your features file has this:
What happens if you try to compile this:
//dev libs
#define WhiteLED 1
#define BlueLED 2
#define FugeLight 3
#define Vortech 4
#ifdef RelayExp
#define ATO 5
#else
#endif
#define Return 6
#define Heater 7
#define Chiller 8
#define Skimmer 14
//#define Feeder 15
void setup(){
ReefAngel.Init();
void loop() {
Posted: Sat Mar 03, 2012 10:40 pm
by javisaman
Yes. And my custom main shows all of the relays.
Posted: Sat Mar 03, 2012 10:43 pm
Did it work?
Posted: Sun Mar 11, 2012 3:13 pm
by rossbryant1956
I am working to get all my relays showing in the portal. What is the difference between this:
#define WhiteLED 1
#define BlueLED 2
#define FugeLight 3
#define Vortech 4
#ifdef RelayExp
#define ATO 5
#else
#endif
#define Return 6
#define Heater 7
#define Chiller 8
#ifdef RelayExp
#define Skimmer 14
//#define Feeder 15
#endif
which I found in this thread, or this:
Ports assignment:
Port1 - Reservoir Heater
Port2 - Standard Lights
Port3 - Moon Lights
Port4 - Refugium Pumps
Port5 - WaveMaker One
Port6 - WaveMaker Two
Port7 - Heater
Port8 - Return Pump
which is the way I do it. I would like these labels to carry forward to all the apps that can read them. Thx
Posted: Sun Mar 11, 2012 3:23 pm
They both won't update the Portal.
Simply go to the tab "Labels" on the Portal and you will be able to change them.
But, just FYI:
The 1st piece of code just makes it easier to code when you are manually coding. So, instead of using for example ReefAngel.Relay.On(Port1), you can used ReefAngel.Relay.On(WhiteLED), because you define that WhiteLED is the same as 1.
The 2nd piece of code does nothing. It's considered comments. Anything in between /* and */ is a comment block and gets stripped off.
Posted: Sun Mar 11, 2012 3:50 pm
by rossbryant1956
Cool. Thx
How do I get my portal to show my second expansion block? It is currently not there. Thx
Posted: Sun Mar 11, 2012 4:05 pm
It does it automatically when you enable the expansion relay on RAGen.
Posted: Sun Mar 11, 2012 4:28 pm
by rossbryant1956
I just went back into ragen and enabled:
number of expansion relays enabled=1
send controller data to portal
do I have to upload anything, recreate a new memory file?
Posted: Sun Mar 11, 2012 4:38 pm
Just to be sure, please check if you have
on your ReefAngel_Features.h file.
Then, simply upload your code again and it should take care of that.
Posted: Tue Mar 13, 2012 6:45 pm
by rossbryant1956
just deleted my "too quick to complain" post. Did all this now works like a charm. Thx
Posted: Thu Jun 21, 2012 2:09 pm
by javisaman
I'm still having this issue:
I changed the code to get rid of all of the flags. My menu on the RA display is fine and the ports seem to be functioning correctly too. When I compile the code I get the following message as well:
Dimming Signal
Salinity Expansion Module
Wifi
Relay Expansion Module
Number of Relay Expasions: 1
Custom Main Screen
Simple Menu
Date/Time Setup Menu
Binary sketch size: 34,886 bytes (of a 258,048 byte maximum)
Here is my code:
//dev libs
#define WhiteLED Port1
#define BlueLED Port2
#define FugeLight Port3
#define Vortech Port4
#define ATOPump Port5
#define Return Port6
#define Heater Port7
#define Chiller Port8
#define KoraliaTank Box1_Port1
#define KoraliaFuge Box1_Port2
#define LiterMeter Box1_Port3
#define Skimmer Box1_Port4
#define SalinityPlug Box1_Port5
void setup(){
ReefAngel.Init();
ReefAngel.AddDateTimeMenu();
ReefAngel.AddWifi();
ReefAngel.Relay.On(SalinityPlug);
void loop() {
ReefAngel.SingleATO(true, ATOPump, 10, 0);
ReefAngel.PWM.SetDaylight(PWMParabola(14,30, 20,30, 0, 25, ReefAngel.PWM.GetDaylightValue()));
ReefAngel.StandardLights(BlueLED, 12, 25, 21, 35);
ReefAngel.PWM.SetActinic(PWMParabola(12, 30, 21, 30, 0, 50, ReefAngel.PWM.GetActinicValue()));
ReefAngel.LCD.DrawDate(6, 20);
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,54, "SAL:" );
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,54, ReefAngel.Params.Salinity );
The webbanner is still only showing the main relay. Which part of the code is for the webbanner? I can look over it myself too and maybe track down the issue.
Posted: Thu Jun 21, 2012 2:31 pm
by javisaman
Hmm even trying RAGen doesn't help. The features file has the RelyExp flag on and the number of InstalledRelayExpansionModules 1
Posted: Thu Jun 21, 2012 2:37 pm
I think you don't have the wifi attachment setup correctly?
Which utility did you use to configure it?
Does it look like this one?
Posted: Thu Jun 21, 2012 3:44 pm
by javisaman
I just tried the new graphical wifi utility. All of the other parameters show up properly, but the second relay still doesn't appear.
I've attached the screenshot. Don't mind the pH and salinity, they haven't been calibrated yet.
The
The XML file coming from the controller is this:
<RA>
<T1>791</T1>
<T2>0</T2>
<T3>0</T3>
<PH>629</PH>
<R>43</R>
<RON>0</RON>
<ROFF>255</ROFF>
<R1>31</R1>
<RON1>0</RON1>
<ROFF1>255</ROFF1>
<R2>0</R2>
<RON2>0</RON2>
<ROFF2>255</ROFF2>
<R3>0</R3>
<RON3>0</RON3>
<ROFF3>255</ROFF3>
<R4>0</R4>
<RON4>0</RON4>
<ROFF4>255</ROFF4>
<R5>0</R5>
<RON5>0</RON5>
<ROFF5>255</ROFF5>
<R6>0</R6>
<RON6>0</RON6>
<ROFF6>255</ROFF6>
<R7>0</R7>
<RON7>0</RON7>
<ROFF7>255</ROFF7>
<R8>0</R8>
<RON8>0</RON8>
<ROFF8>255</ROFF8>
<ATOLOW>0</ATOLOW>
<ATOHIGH>0</ATOHIGH>
<EM>8</EM>
<REM>1</REM>
<PWMA>41</PWMA>
<PWMD>20</PWMD>
<SAL>60</SAL>
</RA>
It doesn't look like it's creating any tags for the relay expansion. Is there a way to check if the flag is being correctly checked in RA_wifi.cpp ? I'm familiar with C++, but not the arduino IDE.
Posted: Thu Jun 21, 2012 4:01 pm
by javisaman
Well if I put junk into the SendXMLData function of RA_wifi.cpp within the RelayExp ifdef, as expected my file doesn't compile because of syntax errors. So I know the flag is set properly, the only thing I can think of is that MAX_RELAY_EXPANSION_MODULES is set to 0 or something. But that also seems unlikely. Very strange indeed.
Posted: Thu Jun 21, 2012 4:07 pm
The XML is fine.
<REM>1</REM> indicates the controller is setup properly, but I'm looking at the log of the portal and it has not received anything from your controller.
So, either your wifi attachment is not configured to send data to reefangel.com.
Sorry, the link didn't go through last time.
Does the wifi utility you used look like this?
http://forum.reefangel.com/viewtopic.php?f=15&t=345
Posted: Thu Jun 21, 2012 4:55 pm
by javisaman
Hmm I didn't use that one apparently, I used the one from the download page. I used that one now, I set it up, but my router doesn't support UPnP. I did setup my router to port forward port 2000. I'm surprised nothing has come from my controller, I can go to the portal page and see everything but the extra relay (as seen in the screenshot). Is there more to it than just enabling the router to port forward?
Posted: Thu Jun 21, 2012 5:19 pm
by javisaman
I enabled UPnP and had the utility set everything up correctly. It still doesn't show the other relay
Posted: Thu Jun 21, 2012 6:29 pm
Yes...
If you are using Dave's utility, make sure that you set the remote settings to send data to reefangel.com
Here is what you need to do:
Plug the wifi attachment into the USB-TTL cable
Open the utility
Connect to the wifi attachment at 57600 baud
On the remote settings section, make sure you choose reefangel.com and click save remote settings.
That should do it.
Posted: Fri Jun 22, 2012 8:47 am
by javisaman
Yep it worked!!!! Thanks!
