date and time are incorrect
Posted: Mon Mar 05, 2012 3:20 pm
by miked
it reads 10/02/00 and time is off. code
// Autogenerated file by RAGen (v1.2.1.158), (03/05/2012 14:24)
// RA_030512_1424.ino
#define DisplayImages
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define SIMPLE_MENU
#define PWMEXPANSION
#define ENABLE_ATO_LOGGING
    ReefAngel.FeedingModePorts = Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port4Bit;
    ReefAngel.Relay.On(Port6);
    ReefAngel.Relay.On(Port7);
    ReefAngel.Relay.On(Port8);
    // Specific functions
    ReefAngel.StandardLights(Port1);
    ReefAngel.MHLights(Port2);
    ReefAngel.StandardLights(Port3);
    ReefAngel.StandardHeater(Port4);
    ReefAngel.SingleATOLow(Port5);
    ReefAngel.Relay.Set(Port5,!ReefAngel.HighATO.IsActive());
    ReefAngel.PWM.SetActinic(PWMSlope(10,0,23,0,5,75,180,5));
    ReefAngel.PWM.SetDaylight(PWMSlope(11,0,21,0,5,65,120,5));
    ReefAngel.Portal("miked");
Re: date and time are incorrect
Posted: Mon Mar 05, 2012 3:24 pm
You can use one of apps to set the time and date.
Client, Status or smart phone.
