stuck in demo
Posted: Tue Mar 06, 2012 1:57 am
by ausreef
probably a stupid question but how do you get the ra out of demo mode,got mine today and whatever i do it just sits there clicking relays on and off,have tried re assinging all the ports on but no luck,have also tried putting in a pwm slope but comes up with a failiure message,also red status light stays on all the time
Re: stuck in demo
Posted: Tue Mar 06, 2012 3:47 am
by ausreef
ive switched from port 3 to 5 and this seems to have fixed the problem,but i cant load a pwm slope it comes up pwmslope not defined and a couple of other messages,where exactly in the pde do i paste it?
ps just fyi the international plug adapters dont fit Australian plugs
Re: stuck in demo
Posted: Tue Mar 06, 2012 8:34 am
Can you post your code?
Re: stuck in demo
Posted: Tue Mar 06, 2012 10:27 am
by binder
It sounds like you have not loaded the Internal Memory file first. The ports are toggling on / off because of the value it reads in for the wavemakers is 0 or another value.
Like Roberto said, let's see your code. Plus, try loading the Internal Memory file first to get the default values set.
Re: stuck in demo
Posted: Tue Mar 06, 2012 8:58 pm
by ausreef
ive now downloaded the internal memory and got the controllerdoing what i want via ragen,im just having trouble putting the pwm slope in my pde canyou tell me anything i need to change and where to paste it
/ Autogenerated file by RAGen (v1.2.1.158), (03/07/2012 14:56)
// RA_030712_1456.ino
#define DisplayImages
#define DateTimeSetup
#define VersionMenu
#define DisplayLEDPWM
#define SIMPLE_MENU
#define PWMEXPANSION
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.On(Port2);
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.On(Port8);
// Specific functions
Re: stuck in demo
Posted: Tue Mar 06, 2012 9:12 pm
by ausreef
ive tried this but still get expected ,)' before token error
// Autogenerated file by RAGen (v1.2.1.158), (03/07/2012 14:56)
#define VersionMenu
#define SIMPLE_MENU
ReefAngel.PWM.SetActinic(PWMSlope(8,30,20,30,15,100,60,0);
ReefAngel.PWM.SetDaylight(PWMSlope(8,30,20,30,15,100,60,0);
Re: stuck in demo
Posted: Tue Mar 06, 2012 9:19 pm
You are missing a ) at the end of each line.
Use this:
ReefAngel.PWM.SetActinic(PWMSlope(8,30,20,30,15,100,60,0));
ReefAngel.PWM.SetDaylight(PWMSlope(8,30,20,30,15,100,60,0));
Re: stuck in demo
Posted: Tue Mar 06, 2012 9:39 pm
by ausreef
your a ledgend Roberto that loaded up ok and i have 9.6v at each pwm port, thanks))))
