what pumps are you guys using for wavemaking?
Posted: Sat Mar 10, 2012 10:54 am
by deva
just want to know what pumps you are using to create waves/random flow in your tank?
anyone have a video? my tank is going to be a softie LPS, nem tank I an love the back and forth movement?
cheers
Deva
Re: what pumps are you guys using for wavemaking?
Posted: Sat Mar 10, 2012 5:48 pm
by psyrob
I use two koralias 1050s.... Set on random times back and forth, about 35-45 seconds each pulse. Then during night time, I make it 20 second pulses with a one minute interval when neither is on...I am very happy wtith the pumps and the wave program... :). Oh the pumps are opposite sides of the tank facing each other
Posted: Sat Mar 10, 2012 6:24 pm
by deva
does it hurt the koralias to be on and off so much? do they ever run backwards?
would love to see a video if you have one! :)
Posted: Sun Mar 11, 2012 10:36 pm
by psyrob
The koralias are designed for lots of on/off...at least that's what the manufacturer says...they have never run backwards on me- hydor fixed that with these pumps...I don't have a video right now maybe I will post one on you tube later this week
Posted: Mon Mar 12, 2012 9:04 am
by wolfador
psyrob wrote:I use two koralias 1050s.... Set on random times back and forth, about 35-45 seconds each pulse. Then during night time, I make it 20 second pulses with a one minute interval when neither is on...I am very happy wtith the pumps and the wave program... :). Oh the pumps are opposite sides of the tank facing each other
This is good to know, I am hoping to use my Koralia 1050 and 750 as wavemakers
Posted: Mon Mar 12, 2012 3:14 pm
by symon_say
I'm using koralias, but they don't work good with wavemakers, the thing that makes then star in the right direction is a small rubber in from of the impeller and this rubber tend to break making then start backward, but that's for the evolution series, the magnum are ok, for wavemaker because they start electronically.
In my setup i have 4 koralia evo 1400, 2 are always on, and the other 2 are on the wavemaker in random mode between 1/2-2 hours, this way the pump don't stress that much from turning on/off, i'll use then until they break or until i have the money for some vortech.
Posted: Mon Mar 12, 2012 3:46 pm
by wolfador
symon_say wrote:I'm using koralias, but they don't work good with wavemakers, the thing that makes then star in the right direction is a small rubber in from of the impeller and this rubber tend to break making then start backward, but that's for the evolution series, the magnum are ok, for wavemaker because they start electronically.
are they the newer Koralias? they redesigned them because of that issue. They even sell their own wave controller for the evo's.
Posted: Tue Mar 13, 2012 5:06 am
by symon_say
Yes they are, i haven't have this problem yet, but their design is like a band-aid over a gun shoot, in normal operation it will last forever, but with constant on/off it will break. That's why i went with higher intervals of time.
Problem with koralia evo is that the correct spin is controlled mechanically, the little rubber in front of impeller, and they will work find while this rubber is there, but if it break you'll have a pump that can start either way.
My tank is new, i set it on October and all the equipment is brand new, if you want pumps that can handle the stress and have a big enough tank go with koralia magnum if your tank is not that big go with jbj ocenstream.
Posted: Wed Mar 14, 2012 11:46 am
by psyrob
Symon_say is right, how they fixed it is to put the thing in there that he is talking about. There doesn't seem to be another way around this issue with non-variable speed pumps. Mine have been going for the past 6 months and no breakage yet...at 35 dollars a pump, I will take what I can get, and hopefully it will be a long time before the rubber thing breaks. I haven't investigated to see if that piece can get replaced..
.Oh, another thing, these are the quietest power heads pumps I have ever owned, it makes a tiny, tiny click each time it goes on, but I have to put my hand on the magnet attachment to feel the vibration to see if it is on, it is that quiet.... :P That is a big plus for me...
Posted: Fri Mar 16, 2012 9:34 am
by deva
hummm....
anyone now if I can use JBJ ocean stream on a RA with out there controller box? I am guessing it would be fine??
magums might be a bit big for my 75 gallon...it's going to be a softie LPS, nem tank so I really would like some back and forth movement.
Posted: Fri Mar 16, 2012 4:09 pm
by symon_say
Yes, JBJ can be use with RA, the controller on jbj is just a simple on/off controller, the same that RA do.
Posted: Fri Mar 16, 2012 6:52 pm
by deva
HUMMM might try it...or just go with 2 mp10.
speaking of MP10s do I need the wireless ES controller or can RA do all the cool stuff that the vortex ES can do?
in other words can I get just the pumps and run then on the Ra and still get all the performance that we pay high dollar for? or would that be like any other pump then?
Posted: Sun Mar 18, 2012 4:49 am
by symon_say
Yes, you'll need the controllers on the pump, what RA do is take control of the wireless controller so you can make the changes from RA instead of the controller.
Posted: Sun Mar 18, 2012 11:07 am
by deva
Ok that's was what I was thinking would be the case...
