finalpasdeAI:205: error: a function-definition is not allowed here before '{' token
finalpasdeAI:226: error: a function-definition is not allowed here before '{' token
//#include <Salinity.h>
//#include <RF.h>
byte WhiteValue=0;
byte BlueValue=0;
byte RoyalBlueValue=0;
//custom dysplay temp+on and off relay
byte x = 6;
byte y = 2;
byte t;
ReefAngel.LCD.DrawDate(6, 2);
x = 12;
y += MENU_START_ROW+1;
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "TEMP pH");
char text[7];
ReefAngel.LCD.Clear(DefaultBGColor, x+16, y+65, x+65, y+16);
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+75, y+18, text, Font8x16);
y += MENU_START_ROW*2;
x = 10;
ReefAngel.LCD.Clear(DefaultBGColor,x,y,x+(16*4),y+16);
ReefAngel.LCD.DrawHugeNumbers(T1TempColor, DefaultBGColor, x, y,text);
ReefAngel.LCD.DrawOutletBox(12, 92, TempRelay);
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(11,30)
#define End_Cloud_Before NumMins(18,30)
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
WhiteValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,WhiteValue,0,180);
else lightningstatus=0;
if (lightningstatus)
WhiteValue=50;
BlueValue=50;
RoyalBlueValue=50;
WhiteValue=0;
BlueValue=0;
RoyalBlueValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
randomSeed(analogRead(0));
ReefAngel.Timer[1].SetInterval(random(10,InternalMemory.WM1Timer_read()));
ReefAngel.Timer[1].Start();
ReefAngel.Relay.On(Port6);
ReefAngel.FeedingModePorts = B00110000;
ReefAngel.OverheatShutoffPorts = B00001110;
ReefAngel.WaterChangePorts = B11110001;
ReefAngel.Relay.On(Port8);
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.On(Port2);
ReefAngel.AI.SetPort(lowATOPin);
ReefAngel.StandardHeater(Port4);
ReefAngel.SingleATOHigh(Port1);
//wave maker fonction with night mode
if ( (hour() >= 22) || (hour() <= 8) ) // from 10p - 8a
ReefAngel.Relay.Off(Port6);
ReefAngel.Relay.On(Port5);
// during the day
ReefAngel.Timer[1].SetInterval(random(25,50));
if (hour()>=22 || hour()<9)
ReefAngel.AI.SetChannel(White,0);
ReefAngel.AI.SetChannel(Blue,MoonPhase()*0.06);
ReefAngel.AI.SetChannel(RoyalBlue,MoonPhase()*0.06);
ReefAngel.AI.SetChannel(White,PWMSlope(9,0,21,0,3,30,200,3));
ReefAngel.AI.SetChannel(Blue,PWMSlope(9,0,21,0,8,35,240,8));
ReefAngel.AI.SetChannel(RoyalBlue,PWMSlope(9,0,21,0,8,35,240,8));
