My new tank - 56G Column
Posted: Sun Mar 18, 2012 4:34 pm
by wolfador
Here is my new tank, just finished moving everything over from my 10G last night.
"Specs:"
Marineland 56G Column
Koralia 750 & 1050
2x Jager 150watt heaters
HOB Reef Octopus BH90 Skimmer
53lbs custom designed, dry rock from reefrocks.net
Aquaclear 70 as HOB Fuge
2x Ai Nano LED lights
Re: My new tank - 56G Column
Posted: Sun Mar 18, 2012 5:21 pm
by binder
Nice. Looking good.
Always so bare when things start up. :)
Posted: Sun Mar 18, 2012 5:39 pm
by wolfador
The few frags I had took up all the space in my 10G. It does make the 56 look empty. Will be adding a few more stuff soon once I am sure everything is stable.
Posted: Sun Mar 18, 2012 8:17 pm
Pretty nice :)
Posted: Sun Mar 18, 2012 8:48 pm
by Rsmolik
That's a nice size tank, are you using RA for this? If so what are you controlling outside of probes and lights?
Posted: Mon Mar 19, 2012 4:21 am
by wolfador
Rsmolik wrote:That's a nice size tank, are you using RA for this? If so what are you controlling outside of probes and lights?
Yes the RA+ is "hidden" in the stand. It is controlling:
  • Ai Nanos, currently controlled together, working on separate control
  • Fuge light
  • both heaters
  • Feed mode / Water change mode is configured to turn off all the pumps
  • I created a "flow" feed mode that turns off the skimmer and fuge but leaves the powerheads on.
I was going to use the koralia's on the wavemaker but I think I got a bad 1050 from amazon as it sometimes jams on startup. Going to see if I can exchange it but I will be going with Vortechs soon.
Posted: Tue Mar 20, 2012 8:27 pm
by Rsmolik
Vortechs are pricey, but amazing, have you looked into the jbj ocean streams? Mine work well and don't reverse on startup like my older koralias.
