LED slope question
Posted: Fri Mar 30, 2012 8:10 pm
I am planning to use the PWM slope to control my LED lights. I did not plan on using an outlet on the relay box as I am using all available sockets for other things. If I set the PWM slope for 15% to 100% for sunrise and 100% to 15% at sunset, does the analog signal go to zero? Theoretically you dont need to turn off the power to the driver just reduce the dimming signal. I am trying to avoid the blinking LED when the signal is to low.
