Wavemaker Function
Posted: Sat Mar 31, 2012 3:21 pm
by dpitalo
trying to add a single powerhead that will come on and off at random.
I added this to my INO
ReefAngel.WavemakerRandom1(Port6,15,60); // Turn Port6 on/off random cycles that lasts from 15 to 60 secs
and get this error.
error: 'class ReefAngelClass' has no member named 'WavemakerRandom1'
Is there something that needs to be enabled in the features file for this to work??
Re: Wavemaker Function
Posted: Sat Mar 31, 2012 4:42 pm
Nothing need to be enabled but i does require at least v0.9.0 libraries.
Posted: Sun Apr 01, 2012 12:48 pm
by dpitalo
Well, that would explain it.
So I updated the libraries and when I go to compile, I get the following error.
C:\Program Files\Reef Angel Controller\libraries\Wire\utility\twi.c: In function 'twi_init':
C:\Program Files\Reef Angel Controller\libraries\Wire\utility\twi.c:70: error: 'SDA' undeclared (first use in this function)
C:\Program Files\Reef Angel Controller\libraries\Wire\utility\twi.c:70: error: (Each undeclared identifier is reported only once
C:\Program Files\Reef Angel Controller\libraries\Wire\utility\twi.c:70: error: for each function it appears in.)
C:\Program Files\Reef Angel Controller\libraries\Wire\utility\twi.c:71: error: 'SCL' undeclared (first use in this function)
Posted: Sun Apr 01, 2012 1:52 pm
How did you update? Did you just use the update utility?
I would suggest you using the Reef Angel Installation program because you have to use the latest arduino to get it to work.
Posted: Sun Apr 01, 2012 2:04 pm
by dpitalo
I used the installer for version 0.9.4. Using Arduino v1.0
It's not a huge rush since my controller is up and running with the old code/libraries, but I wanted to add the wavemaker function.
Posted: Sun Apr 01, 2012 3:35 pm
by dpitalo
I also tried loading some of the example code snip-its and compiling them and it's giving me the same error.
Posted: Sun Apr 01, 2012 5:26 pm
by dpitalo
Ok, so I went digging through the file in question called twi.c
I have no idea what this file does, but I commented out the following two lines.
digitalWrite(SDA, 1);
digitalWrite(SCL, 1);
and the sketch compiled...Before I go and upload it to my controller, how necessary are the two lines I commented out??
Posted: Sun Apr 01, 2012 6:22 pm
If you had to comment them, you got something else wrong.
My suggestion is rename your libraries folder to librariesold and update with
http://www.reefangel.com/update
The libraries folder is located at "Documents/Arduino/libraries"
Posted: Sun Apr 01, 2012 6:42 pm
by dpitalo
did what you suggested and got the same result.
Here's the PDE.
#define AutoTopOff 1
#define Skimmer 2
#define Port3 3
#define Heater 4
#define WM1 5
#define WM2 6
#define SeaSwirl 7
#define Return 8
Ports assignment:
Port1 - Standard ATO - "http://forum.reefangel.com/viewtopic.php?f=7&t=240"
Port2 - Skimmer
Port3 - Port3
Port4 - Heater - "http://www.reefangel.com/Support.Relay-function-StandardHeater.ashx"
Port5 - Wavemaker 1
Port6 - Wavemaker 2 - "http://www.reefangel.com/Support.Activating-a-relay.ashx"
Port7 - SeaSwirl
Port8 - Return
#define PWMRB1 0
#define PWMRB2 1
#define PWMRB3 2
#define PWMWT1 3
#define PWMWT2 4
#define PWMHN 5
byte PWMChannel[]={
0,0,0,0,0,0};
ReefAngel.Init();
ReefAngel.FeedingModePorts = Port2Bit | Port5Bit | Port6Bit | Port8Bit; // Turn off Port6 and Port8 when feeding mode is activated
ReefAngel.WaterChangePorts = Port2Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit; // Turn off Port5, Port6, Port7 and Port8 when water change mode is activated
ReefAngel.Relay.DelayedOn(Skimmer,2); // Turn on Port 7
ReefAngel.Relay.On(SeaSwirl); // Turn on Port 7
ReefAngel.Relay.On(Return); // Turn on Port 8
ReefAngel.StandardATO(AutoTopOff, 60); // ATO with 60 seconds timeout
ReefAngel.StandardHeater(Heater,788,792); // Heater on at 77.0F and off at 78.0F
ReefAngel.WavemakerRandom(WM2,15,60); // Turn Port5 on/off random cycles that lasts from 15 to 60 secs
if (hour()>=21 || hour()<10)
ReefAngel.PWM.SetActinic(0);
//************************************************************ Start of PWM Expansion Code for Slope
PWMChannel[PWMRB2]=PWMSlope(9,30,21,20,0,95,60,PWMChannel[PWMRB2]); //Royal Blue - Left Bank
PWMChannel[PWMRB3]=PWMSlope(9,50,21,40,0,95,60,PWMChannel[PWMRB3]); //Royal Blue - Middle Bank
PWMChannel[PWMRB1]=PWMSlope(10,10,22,00,0,95,60,PWMChannel[PWMRB1]); //Royal Blue - Right Bank
PWMChannel[PWMWT2]=PWMSlope(11,00,21,00,0,95,80,PWMChannel[PWMWT2]); //XP-E Cool Whites - Left Side
PWMChannel[PWMWT1]=PWMSlope(11,10,21,30,0,95,80,PWMChannel[PWMWT1]); //XP-E Cool Whites - Right Side
PWMChannel[PWMHN]=PWMSlope(12,00,20,00,0,95,120,PWMChannel[PWMHN]); //XP-G Cool Whites - Left Side
if (hour()>=21 || hour()<12)
ReefAngel.PWM.SetDaylight(0);
ReefAngel.PWM.SetDaylight(PWMSlope(12,00,20,30,0,95,120,ReefAngel.PWM.GetDaylightValue())); //XP-G Cool Whites - Right Side
for (int a=0;a<6;a++)
ReefAngel.PWM.Expansion(a,int(2.55*PWMChannel[a]));
//************************************************************* End of PWM Expansion Code for Slope
Posted: Sun Apr 01, 2012 7:12 pm
I just tested it and it compiles fine.
Maybe you have not uninstalled the previous version of installer.
Try uninstalling the old versions and install the new one again.
Posted: Mon Apr 02, 2012 8:09 am
by dpitalo
That fixed it.
Thanks Roberto!
