Page 1 of 3
Re: tunze controllable pumps
Posted: Thu Sep 29, 2011 6:23 pm
by Bryan
Later tonight I will first scope the outputs of the Tunze controller and see what it.
Posted: Fri Sep 30, 2011 2:36 am
by Bryan
Roberto:
Ok, here is the scope results from my 7091 controller. The minimum running voltage for the Tunze is supposedly 30%, which seems to jive with the scope at 3.9v. What is odd is the Full ON voltage was only 7.3, thought it would be 10v, perhaps it's my controller. Would have thought full power would be 10v
The pics should be self-explanatory. Does this help.?
Posted: Fri Sep 30, 2011 7:57 am
Nice!!!
Thanks Bryan!!!
Just to confirm:
Pin 1 - PWM signal
Pin2 - GND
Is it correct?
Posted: Fri Sep 30, 2011 8:06 am
Oh, and to explain your question, with PWM signals, the receiver (pump in this case) usually doesn't care how much voltage the controller is sending.
Meanwell drivers are an exception though. They actually built it so it does matter. My theory is that they wanted to make convertion between D and P very simple, so the core electronics actually checks analog signals, instead of just PWM.
So for the receiver, what matters is how long the "Pump On voltage" in your design, stays at that level.
I'm guessing the pump only looks as if is it above 5V or below 5V to determine 0 or 1 binary state.
Posted: Fri Sep 30, 2011 12:45 pm
by Bryan
rimai wrote:Oh, and to explain your question, with PWM signals, the receiver (pump in this case) usually doesn't care how much voltage the controller is sending.
Hi Roberto:
I don't think I explained myself and should have documented the scope picture better, but from the picture of the 7091 there is three knobs, Pulse, power1 and power 2. Pulse sets the duty/switching rate between power 1 and power 2. Power 1 setting is between 30-100% in voltage. Power 2 is the same 30-100%. (tunze pumps can't be run below 30%). So in summary the pump will run at 100% for
So from the scope pic Power 1 is on for roughly 2.5 seconds (Pump On time in picture) and at a voltage of ~7.5v (was set to MAX for the test), then it switches to Power 2 for approx 1.75s (Pump Off time in picture) for a voltage of ~3.9v (was set to MIN for the test). Not sure how u would use PWM to control this. Basically the driver needs a voltage from the controller at 0-10v, although my 7091 peaks at around 8v, so I may have that point wrong.
So in summary what u are seeing on the scope is the pump running at full power for 2.5 seconds and then at minimum power for 1.75s. Full power being 7.9v and low power being 3.9v.
Hope this helps
Posted: Fri Sep 30, 2011 12:48 pm
by Bryan
rimai wrote:Nice!!!
Thanks Bryan!!!
Just to confirm:
Pin 1 - PWM signal
Pin2 - GND
Is it correct?
Sent PM
Posted: Fri Sep 30, 2011 1:09 pm
by Bryan
Hope this helps
Just to add, if I set the power 1 and power 2 knobs to MIN for both the scope would displaya flat line at 3.9v, if set to MAX for both Power 1 and Power 2 the scope would display a flat line of 7.9v.
So if the power 1 and power 2 are set identical there is no switching that takes place between the pumps, as they are running at identical voltage..
Posted: Fri Sep 30, 2011 5:19 pm
Thanks Bryan.
I now understand how they work and I can say for sure it is not PWM, but analog signal.
Posted: Fri Sep 30, 2011 6:50 pm
by Bryan
Yup, afraid so, so don't think it would be a easy task on the existing RA hardware.
Posted: Fri Sep 30, 2011 7:52 pm
Oh no, it's still pretty simple.
All we need to do is smooth down the PWM signal.
We already have 0-10VDC PWM signal.
The cable assembly only needs a resistor and a capacitor, which is fairly simple to do.
Posted: Sun Oct 02, 2011 8:30 am
Tunze pinout
Posted: Mon Oct 17, 2011 6:21 am
by Xender
Hi
Do you think I can DIM my TUNZE Nano-Stream 6025 with one of the two PWM channel on the relay box?
Thanks.
Posted: Mon Oct 17, 2011 8:14 am
I sent a cable to cain to test, but it did not work.
Without having one with me to test what kind of load is being applied by the Tunzes on the RC filter I created, it is hard to find out which values to use.
I tried 1uF and 10K and it did not work.
In theory, all you need is to do is convert the PWM signal to analog and plug it in on the Tunze connector.
Posted: Mon Oct 17, 2011 9:47 am
by cain
Xender wrote:Hi
Thanks.
NO, since a 6025 is not controllable.
Posted: Mon Oct 17, 2011 11:43 pm
by Xender
thanks cain
Posted: Fri Feb 03, 2012 6:59 am
by symon_say
Have anybody found a solution to control tunze pumps??
Posted: Fri Feb 03, 2012 10:44 am
I can give it another try.
My last attempt was unsuccessful, but I'm pretty sure I know how to fix the problem now.
PM me if you would like to test the module?
Posted: Tue Feb 07, 2012 1:30 pm
by hylik
i maybe interested on this module too if it become available
Posted: Fri Feb 10, 2012 5:04 am
by bluwinghawk
following
Posted: Tue Mar 20, 2012 8:07 pm
Ok, so I got ahold of a Tunze :)
I was able to control it this time!!!
Requires the analog dimming version of relay box.
Posted: Wed Mar 21, 2012 9:54 am
by abhi_123
rimai wrote:Ok, so I got ahold of a Tunze :)
Which model number of tunze pump mate?
Posted: Wed Mar 21, 2012 9:59 am
I'll check when get home.
Posted: Wed Mar 21, 2012 6:24 pm
by J_C
Awesome, so when can I start controlling my 6055?
Posted: Wed Mar 21, 2012 7:56 pm
Posted: Thu Mar 22, 2012 6:01 am
by abhi_123
bad luck man.
Posted: Thu Mar 22, 2012 8:01 am
You should have an idea by looking at the controller, right?
Posted: Thu Mar 22, 2012 9:51 am
by abhi_123
do we need tunze controller to control their wavers or simply by using analog RA?
Posted: Thu Mar 22, 2012 9:57 am
You need their controller.
I mean, you need their driver
Posted: Thu Mar 22, 2012 10:46 am
by abhi_123
i was looking into their site havnt find there anything related to drivers.
