controller reseting every minute
Posted: Sat Aug 25, 2012 1:28 am
by pilonstar
Hi Folks!
I find my controller lately reseting by itself every minute and sometimes every second.
I have tried to reset the controller and setup the memory and started it from 0 but I doesn´t
work...keeps reseting. I have a video if it helps.
http://www.youtube.com/watch?v=-wE6IUuWwXc
[youtube]http://www.youtube.com/watch?v=-wE6IUuWwXc[/youtube]
Thank you in advance.
Erick
Re: controller reseting every minute
Posted: Sat Aug 25, 2012 9:06 am
Does it do that with the Template code too?
File->Sketchbook->Example Codes->Template
Posted: Sun Aug 26, 2012 2:59 am
by pilonstar
rimai wrote:Does it do that with the Template code too?
I have tried that one too and stops for a while but once I put mine goes nuts:
        ReefAngel.Relay.On( Port2 );
        ReefAngel.Relay.On( Port3 );
        ReefAngel.Relay.On( Port5 );
        ReefAngel.Relay.On( Port7 );
    ReefAngel.MHLights(Port1);
    ReefAngel.StandardHeater(Box1_Port2);
    ReefAngel.StandardLights(Port4);
    ReefAngel.StandardFan( Port6 );
    ReefAngel.SingleATOLow( Box1_Port1 );
      ReefAngel.RF.RadionChannels[Radion_Intensity]=75;
      ReefAngel.RF.RadionChannels[Radion_White]=PWMParabola(12,0,18,0,0,100,0);
      ReefAngel.RF.RadionChannels[Radion_RoyalBlue]=PWMParabola(9,0,22,0,0,100,0);
      ReefAngel.RF.RadionChannels[Radion_Red]=PWMParabola(9,0,22,0,0,5,0);
      ReefAngel.RF.RadionChannels[Radion_Green]=PWMParabola(9,0,22,0,0,10,0);
      ReefAngel.RF.RadionChannels[Radion_Blue]=PWMParabola(10,0,21,0,0,60,0);
      if (second()==0) ReefAngel.RF.RadionWrite();
    ReefAngel.Portal( "pilonstar" );
    int x,y;
    // I/O Expansion
    byte bkcolor;
    x = 14;
    y = 11;
    for ( int a=0;a<6;a++ )
    ReefAngel.LCD.DrawMonitor( 15, 26, ReefAngel.Params,
    ReefAngel.LCD.DrawMonitor( 15, 26, ReefAngel.Params );
    // Salinity
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,63, "SAL:" );
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,63, ReefAngel.Params.Salinity );
    ReefAngel.LCD.DrawOutletBox( 12, 82, TempRelay );
    // Relay Expansion
    ReefAngel.LCD.DrawOutletBox( 12, 101, TempRelay );
It happened when I messed with the Radion codes :(
Thanks for your patience and fast reply.
Posted: Sun Aug 26, 2012 8:25 am
I posted the original firmare on the other thread for you to try to revert back and see if it makes any difference.
Posted: Tue Aug 28, 2012 2:07 am
by pilonstar
rimai wrote:I posted the original firmare on the other thread for you to try to revert back and see if it makes any difference.
After resetting all from zero, the controller is working back perfect! yay!! Thank you so much Mr Rimai, Really appreciated your patience and help :D
