Page 1 of 2
problem ph
Posted: Fri Dec 14, 2012 7:14 am
by marco3020
hello to all I have this problem I put the pH probe into the calcium reactor but I can only calibrate the reef angel to 7 or 10 that the reactor is not good coem do I set it to 4 and 7 in the reef angel?
problem ph
Posted: Fri Dec 14, 2012 7:56 am
by dbmet
Re: problem ph
Posted: Fri Dec 14, 2012 10:01 am
by marco3020
thanks i have add this code ReefAngel.UseFlexiblePhCalibration (); in setup dont fuction help me
Re: problem ph
Posted: Fri Dec 14, 2012 10:24 am
by marco3020
i have add this
Re: problem ph
Posted: Fri Dec 14, 2012 10:30 am
Go though the calibration now.
It will let you pick which numbers you want to use for calibration.
Use the joystick to move to the ph number and then select which one you want.
Re: problem ph
Posted: Fri Dec 14, 2012 10:37 am
by marco3020
dont charge this code have problem in when add this code ReefAngel.UseFlexiblePhCalibration ();
Re: problem ph
Posted: Fri Dec 14, 2012 12:23 pm
What libraries version are you using?
Sent from my Galaxy S3 using Tapatalk 2
Re: problem ph
Posted: Mon Dec 17, 2012 3:19 am
by marco3020
good morning now works, but the problem is that I do not know if the probe is to be changed, in a few words when I enter the ra to calibrate ph ph 4 mi marks 120 and does not go below 50 and the same with ph 7, I tried to leave the probe in pH 4 a night but nothing ever 126 marks what should I do?
Re: problem ph
Posted: Mon Dec 17, 2012 8:05 am
by marco3020
help me please
Re: problem ph
Posted: Mon Dec 17, 2012 9:12 am
What is the reading you get for 4 and 7?
Re: problem ph
Posted: Mon Dec 17, 2012 9:54 am
by marco3020
kh is from 4 to 128 and down to 50
7 is for kh 230 and goes up to 100
Re: problem ph
Posted: Mon Dec 17, 2012 10:43 am
Huh??
What kh?
Re: problem ph
Posted: Mon Dec 17, 2012 11:20 am
by marco3020
Let me explain by placing the probe in the solution of the reef angel 4 and going in the ra ph calibrazioen also scuotenso the probe does not give me less than 50 is put in solution 4 and 7 solution
Re: problem ph
Posted: Mon Dec 17, 2012 11:36 am
Why do you think it needs to be less than 50?
Re: problem ph
Posted: Mon Dec 17, 2012 5:14 pm
by marco3020
I think for on 4 04 and on 7 07 correct?
problem ph
Posted: Mon Dec 17, 2012 5:20 pm
by dbmet
Those numbers you are seeing in the calibration screen aren't the actual ph numbers. They are used to calibrate the control.
Re: problem ph
Posted: Tue Dec 18, 2012 12:28 am
by marco3020
then how do I calibrate the probe to 4 and 7? what numbers do I look?
Re: problem ph
Posted: Tue Dec 18, 2012 5:36 am
by marco3020
explane please!
problem ph
Posted: Tue Dec 18, 2012 6:50 am
by dbmet
Calibrate the probe using the calibrate screen by using the 4 solution and then the 7 solution and then exit out of the calibration to the main screen. Now you can verify from the main screen by putting the probe in the 4 solution and seeing what it reads on the main screen then do the same for the 7 solution.
Re: problem ph
Posted: Tue Dec 18, 2012 7:16 am
by Sebyte
Take a look at this topic it might be what you are looking for.
http://forum.reefangel.com/viewtopic.ph ... tion#p2210
Re: problem ph
Posted: Tue Dec 18, 2012 7:32 am
by marco3020
thanks
Re: problem ph
Posted: Tue Dec 18, 2012 7:45 am
by marco3020
how do I make the count of those numbers for ph 4 and 7?
Re: problem ph
Posted: Tue Dec 18, 2012 9:43 am
The numbers you see during calibration are the raw 8-bit ADC value that Arduino has internally.
It's a value that goes from 0 to 1023.
ph 7 is around 540 in that range and ph10 is around 830. So, for ph4, you will be looking at somewhere around 250 if my math is correct....
Re: problem ph
Posted: Tue Dec 18, 2012 12:34 pm
by marco3020
ok thanks
Re: problem ph
Posted: Thu Dec 20, 2012 4:05 am
by marco3020
hello I tried to calibrate the pH and after an hour in kh 4 mi marks the maximum number of controller 86 and kh 7-329
Re: problem ph
Posted: Thu Dec 20, 2012 5:40 am
by marco3020
Where should I put these two lines?
ReefAngel.PH Min = 250;
ReefAngel.PHMax = 512?
Re: problem ph
Posted: Thu Dec 20, 2012 6:46 am
by marco3020
good this?
Re: problem ph
Posted: Thu Dec 20, 2012 8:54 am
You don't need those lines.
Just go through calibration and make sure you pick ph4 and ph7 as reference or it won't work.
Re: problem ph
Posted: Thu Dec 20, 2012 9:07 am
by marco3020
I have to cancel these lines?
Re: problem ph
by marco3020
when time for calibration ph 4 and 7 in total?
