ORP as a controller
Posted: Sun Dec 16, 2012 7:03 am
Can i use the orp expantion as a controller to turn ozone unit on and off?
https://forum.reefangel.com/
Yes, you can do this. I do not believe this functionality is built into the libraries. You can do something like this:butcherman wrote:Can i use the orp expantion as a controller to turn ozone unit on and off?
if (ReefAngel.Params.ORP >= 400 ) ReefAngel.Relay.Off(Port8);
if (ReefAngel.Params.ORP <= 300 ) ReefAngel.Relay.On(Port8);
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit;
ReefAngel.OverheatShutoffPorts = Port5Bit | Port7Bit;
ReefAngel.StandardATO( Port1,120 );
ReefAngel.StandardLights( Port2,7,0,20,0 );
ReefAngel.StandardLights( Port3,7,0,20,0 );
ReefAngel.StandardFan( Port4,250,260 );
ReefAngel.StandardHeater( Port5,240,250 );
ReefAngel.StandardHeater( Port7,240,250 );
ReefAngel.PWM.SetDaylight( PWMParabola(9,0,20,0,11,100,11) );
ReefAngel.PWM.SetActinic( PWMParabola(9,0,20,0,10,100,10) );
ReefAngel.Portal( "butcherman" );
int x,y;
// ORP
ReefAngel.LCD.DrawText( COLOR_PALEVIOLETRED,DefaultBGColor,75,66, "ORP:" );
ReefAngel.LCD.DrawText( COLOR_PALEVIOLETRED,DefaultBGColor,99,66, ReefAngel.Params.ORP );
}i incorperated it in the coderimai wrote:No, it won't work
You will need to use the code posted by binder
