ORP as a controller
ORP as a controller
Can i use the orp expantion as a controller to turn ozone unit on and off?
Re: ORP as a controller
Yes, you can do this. I do not believe this functionality is built into the libraries. You can do something like this:butcherman wrote:Can i use the orp expantion as a controller to turn ozone unit on and off?
if (ReefAngel.Params.ORP >= 400 ) ReefAngel.Relay.Off(Port8);
if (ReefAngel.Params.ORP <= 300 ) ReefAngel.Relay.On(Port8);
You would place this code inside your loop() along with the other functions. You can also change the values. I do not know what values are good for ORP, so I just picked some to use as an example.
Can i use the ph funcion on port8 on the wizzard and change the ph code to orp code?
will this work
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit;
ReefAngel.OverheatShutoffPorts = Port5Bit | Port7Bit;
ReefAngel.StandardATO( Port1,120 );
ReefAngel.StandardLights( Port2,7,0,20,0 );
ReefAngel.StandardLights( Port3,7,0,20,0 );
ReefAngel.StandardFan( Port4,250,260 );
ReefAngel.StandardHeater( Port5,240,250 );
ReefAngel.StandardHeater( Port7,240,250 );
ReefAngel.PWM.SetDaylight( PWMParabola(9,0,20,0,11,100,11) );
ReefAngel.PWM.SetActinic( PWMParabola(9,0,20,0,10,100,10) );
ReefAngel.Portal( "butcherman" );
int x,y;
// ORP
ReefAngel.LCD.DrawText( COLOR_PALEVIOLETRED,DefaultBGColor,75,66, "ORP:" );
ReefAngel.LCD.DrawText( COLOR_PALEVIOLETRED,DefaultBGColor,99,66, ReefAngel.Params.ORP );
i incorperated it in the coderimai wrote:No, it won't work
You will need to use the code posted by binder
thx, as soon as i get some orp calibration fluid ill try it out.
if i change the library code can i use 220mV calibration fluid?
Thanks will see what i can get me hands on.
how do I know if the orp expansion os working. I have a STD pwm module wifi unit and orp expansion module. I have loaded the code and ,injected the expansion module. The orp readout remains 0 even in calibration fluid. After calibration. There are do values displayed during calibration either besides 0. What should I try to test the expansion module or the USB port on the relay box?
Sent from my GT-I9100 using Tapatalk 2
I will re-check that.
Anything else?
Anything else?
My unit only had one jumper I had only moved it. I added a second and it and now it seems to be working. do I need both jumpers inplace?
You need all 3.
If you are missing any and don't have laying around, send me a PM
I have spares from old hard drives and cdroms, I'll put in all 3
