Need a little help again
treetopflyn
Post by treetopflyn »
I want to start over with my code as I was having a little trouble and wanted to eliminate a couple of things.
Below is my current code. For now the only things I would like to add is
1. Starting at 7:00am I would like one of the Wave Maker outlets to stay on for 3.5 hours while the other one switches on and off randomly. Every 3.5 hours I would like them to switch with both going off at 9pm and restarting at the cycle at 7:00am.
Roberto I know you did this for me before but I can't figure out what and where to add it in this code.
Thanks in advance
K
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <ReefAngel.h>
// This must be the first line
// Ports toggled in Feeding Mode
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
// Ports toggled in Water Change Mode
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
// Ports toggled when Lights On / Off menu entry selected
// Ports turned off when Overheat temperature exceeded
// Use T1 probe as temperature and overheat functions
// Set the Overheat temperature setting
InternalMemory.OverheatTemp_write( 889 );
// Ports that are always on
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port4 );
////// Place additional initialization code below here
////// Place additional initialization code above here
ReefAngel.StandardATO( Port1,60 );
if (hour()>=21 || hour()<7)
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
ReefAngel.WavemakerRandom1( Port5,30,90 );
ReefAngel.WavemakerRandom2( Port6,30,90 );
ReefAngel.Relay.DelayedOn( Port7,0 );
////// Place your custom code below here
////// Place your custom code above here
// This should always be the last line
ReefAngel.Portal( "treetopflyn" );
int x,y;
// Parameters
#if defined DisplayLEDPWM && ! defined RemoveAllLights
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params,
#else // defined DisplayLEDPWM && ! defined RemoveAllLights
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params );
#endif // defined DisplayLEDPWM && ! defined RemoveAllLights
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,54, "PHE:" );
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,54, ReefAngel.Params.PHExp );
// Main Relay Box
TempRelay &= ReefAngel.Relay.RelayMaskOff;
TempRelay |= ReefAngel.Relay.RelayMaskOn;
ReefAngel.LCD.DrawOutletBox( 12, 74, TempRelay );
// Relay Expansion
TempRelay = ReefAngel.Relay.RelayDataE[0];
TempRelay &= ReefAngel.Relay.RelayMaskOffE[0];
TempRelay |= ReefAngel.Relay.RelayMaskOnE[0];
ReefAngel.LCD.DrawOutletBox( 12, 97, TempRelay );
// Date and Time
Re: Need a little help again
treetopflyn
I no longer wanted the pumps coming on for 10 min when the ATO comes on, so I went back to my original code. This stuff is all greek to me so I had no clue what to remove/insert so I went back to the code I knew worked without the ATO code
Let's try this:
//      ReefAngel.WavemakerRandom1( Port5,30,90 );
//      ReefAngel.WavemakerRandom2( Port6,30,90 );
      if (elapsedSecsToday(now())%25200<12600)
  int x,y;
  // pH Expansion
  // Relay Expansion
treetopflyn
Appears to be working. I'll know for sure at 2:00 when they should switch. Thank you very much.
K
