Reef angel not in sync while uploading
Posted: Fri Apr 05, 2013 2:34 pm
I just bought a used Reef ANgel controller and wanted to upload code but got an error
Watchdog Timer
Version Menu
Simple Menu
Binary sketch size: 6,804 bytes (of a 32,256 byte maximum)
C:\Program Files (x86)\Reef Angel\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P\\.\COM3 -b115200 -D -Uflash:w:C:\Users\Owner\AppData\Local\Temp\build6006547708882342743.tmp\InitialInternalMemory.cpp.hex:i
Copyright (c) 2000-2005 Brian Dean,
System wide configuration file is "C:\Program Files (x86)\Reef Angel\hardware/tools/avr/etc/avrdude.conf"
Using Port : \\.\COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude done. Thank you.
I read all the troubleshooting tips but no luck any help would be much appreciated.
Watchdog Timer
Version Menu
Simple Menu
avrdude: Recv:
