USB to Network Converter
Posted: Mon Oct 03, 2011 12:21 pm
by 02vetteboy
I am wondering if I could use a USB to Netwrok cable converter so I can plu the Reef Angel in to a netwrok plu in my fish room that is hard wired to my router? Has anyone tried this? If so how did it work?
Re: USB to Network Converter
Posted: Mon Oct 03, 2011 2:19 pm
The RA does not have a USB port.
Wifi is the easiest way to tap into your network.
Posted: Mon Oct 03, 2011 2:58 pm
by 02vetteboy
THe RA uses a TTl to usb cable to connect to the computer correct? If I went from that cable to a usb to network adapter then hard wired to a router would that work? I am thinking something like this.
Posted: Mon Oct 03, 2011 3:18 pm
It doesn't work that way.
You need a host to implement the USB protocol.
If you could find a serial TTL to Ethernet, it would work for you.
Posted: Mon Oct 03, 2011 3:21 pm
by 02vetteboy
Thank you for the quick reply. I am going to start looking for an alternative to what I had origanally planned.
