ReefAngel Client v2.2 masking issue
Posted: Mon Oct 10, 2011 12:59 pm
by agentgreen
I installed the ReefAngel Client v2.2 and so far am really liking it. Nice job!
I am seeing a strange issue, and I'm not 100% sure its due to the client software, but it seems this issue cropped up after connecting the client.
Just to confirm, when there is a blue box surrounding a relay, that means it's masked by the client software, right? I'm talking about this:
So it appears my MH2, Fans and NA are masked OFF, right?
Well, when I set them back to Auto (click OFF, choose Auto) the relays switch to ON, like they should be, but then immediately go back to masked off.
I checked the relay profile for this relay box, and it's only using the Auto profile, which has all relays set to Auto.
Anything I'm missing?
Re: ReefAngel Client v2.2 masking issue
Posted: Mon Oct 10, 2011 2:59 pm
Can you post your entire code?
It could be your overheat mask.
Posted: Mon Oct 10, 2011 3:13 pm
by agentgreen
// Autogenerated file by RAGen (v1.0.4.92), (09/09/2011 07:48)
// RA_090911_0748.pde
#define DisplayImages
#define WavemakerSetup
#define DateTimeSetup
#define VersionMenu
#define MetalHalideSetup
#define DirectTempSensor
#define DisplayLEDPWM
#define StandardLightSetup
#define RelayExp
Box 0 Port 1 = MH1
Box 0 Port 2 = MH2
Box 0 Port 3 = Canopy Fans
Box 0 Port 4 = Powerhead 1
Box 0 Port 5 = Powerhead 2
Box 0 Port 6 = Heater 1
Box 0 Port 7 = EMPTY
Box 0 Port 8 = EMPTY
Box 1 Port 1 = Return Pump
Box 1 Port 2 = Skimmedr
Box 1 Port 3 = Refugium Light
Box 1 Port 4 = ATO
Box 1 Port 5 = EMPTY
Box 1 Port 6 = EMPTY
Box 1 Port 7 = EMPTY
Box 1 Port 8 = EMPTY
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
// Labels for the web banner
#include <avr/pgmspace.h>
prog_char id_label[] PROGMEM = "agentgreen";
prog_char probe1_label[] PROGMEM = "Sump";
prog_char probe2_label[] PROGMEM = "Canopy";
prog_char probe3_label[] PROGMEM = "Not%20Used";
prog_char relay1_label[] PROGMEM = "MH1";
prog_char relay2_label[] PROGMEM = "MH2";
prog_char relay3_label[] PROGMEM = "FANS";
prog_char relay4_label[] PROGMEM = "PH1";
prog_char relay5_label[] PROGMEM = "PH2";
prog_char relay6_label[] PROGMEM = "H1";
prog_char relay7_label[] PROGMEM = "H2";
prog_char relay8_label[] PROGMEM = "NA";
prog_char relay11_label[] PROGMEM = "Return";
prog_char relay12_label[] PROGMEM = "Skimmer";
prog_char relay13_label[] PROGMEM = "RefugLight";
prog_char relay14_label[] PROGMEM = "ATO";
prog_char relay15_label[] PROGMEM = "NA";
prog_char relay16_label[] PROGMEM = "NA";
prog_char relay17_label[] PROGMEM = "NA";
prog_char relay18_label[] PROGMEM = "NA";
relay3_label, relay4_label, relay5_label, relay6_label, relay7_label, relay8_label,
relay11_label, relay12_label, relay13_label, relay14_label, relay15_label, relay16_label,
relay17_label, relay18_label};
void WifiSendAlert(byte id, boolean IsAlert)
static byte alert_status;
if (IsAlert)
if ((alert_status & 1<<(id-1))==0)
alert_status|=1<<(id-1);
Serial.print("GET /status/alert.asp?e=4048587609@vtext.com&id=");
Serial.println(alert_status,DEC);
Serial.println("\n\n");
if (id==0)
alert_status=0;
delay(900);
alert_status&=~(1<<(id-1));
// Initialize and start the web banner timer
ReefAngel.Timer[4].Start();
ReefAngel.FeedingModePorts = B00011000;
ReefAngel.WaterChangePorts = B00011000;
ReefAngel.WaterChangePortsE[0] = B11000000;
ReefAngel.OverheatShutoffPorts = B11000110;
ReefAngel.LightsOnPorts = B11000000;
ReefAngel.LightsOnPortsE[0] = B00100000;
ReefAngel.OverheatTempProbe = &ReefAngel.Params.Temp1;
// Return pump
// Specific functions
ReefAngel.MHLights(Port1);
ReefAngel.MHLights(Port2);
ReefAngel.Wavemaker1(Port4);
ReefAngel.Wavemaker2(Port5);
ReefAngel.StandardHeater(Port6);
ReefAngel.StandardLights(Box1_Port3);
//ReefAngel.DelayedOn(Box1_Port2, 2);
ReefAngel.Relay.DelayedOn(Box1_Port2, 2);
// Turn on Port 3 when the temp of T2 gets above 85.0 degrees
if ( ReefAngel.Params.Temp2 >= 850 ) ReefAngel.Relay.On(Port3);
// Turn off Port 3 when the temp of T2 gets below 80.0 degrees
if ( ReefAngel.Params.Temp2 <= 800 ) ReefAngel.Relay.Off(Port3);
// Turn on moon lights based on moon phases between 10pm and 9am.
if ( hour() > 22 || hour() < 9)
ReefAngel.PWM.SetActinic(100);
ReefAngel.PWM.SetDaylight(100);
// Web Banner stuff
ReefAngel.WebBanner();
// Only turn on ATO for 20 minutes every hour.
if (minute()<=20)
ReefAngel.Relay.On(Box1_Port4);
} else {
ReefAngel.Relay.Off(Box1_Port4);
//This will send an alert if T1 is below 77 and reset if above 78
if (ReefAngel.Params.Temp1<770 && ReefAngel.Params.Temp1>0) WifiSendAlert(3,true);
if (ReefAngel.Params.Temp1>780 && ReefAngel.Params.Temp1<1850) WifiSendAlert(3,false);
//This will send an alert if T1 is above 83 and reset if below 80
if (ReefAngel.Params.Temp1>830 && ReefAngel.Params.Temp1>1850) WifiSendAlert(4,true);
if (ReefAngel.Params.Temp1<800 && ReefAngel.Params.Temp1>0) WifiSendAlert(4,false);
Posted: Mon Oct 10, 2011 3:48 pm
According to this line:
You are masking off Port 2,3,7,8.
So, in the picture above, Port 7 should've been masked off.
Maybe you picked the wrong ports when creating the code.
I think what you really meant was:
ReefAngel.OverheatShutoffPorts = B01100011;
Which is port 1,2,6,7
It's the tricky of writing in binary. The left most is the most significant, which means the left most is always the biggest.
I think what you have to check too is the overheat temperature setting in the internal memory. That's what is triggering the overheat.
Posted: Mon Oct 10, 2011 4:09 pm
by agentgreen
Ahhh. You actually answered another question I was going to have too!
I wasn't sure which order to use when setting those things.
Thanks, I'll make the changes and see if it resolves.
Posted: Mon Oct 10, 2011 4:14 pm
Oh, by the way, on your code you mention moonphase in the comments, but your code sets the channels to 100%.
Was it what you intended or you wanted to have it go according to the moon cycles?
Posted: Mon Oct 10, 2011 4:16 pm
by agentgreen
I couldn't get the moonphase stuff to work, I don't know why. I don't even think the time range to set the PWMs to 100% is working right. For instance, my moon lights are on right now, and they shouldn't be!
I feel like when I first set this up, I pushed some PWM settings to memory, which are overriding the moonphase settings, or my time range settings.
Posted: Mon Oct 10, 2011 4:19 pm
by agentgreen
Ok, I just pushed new code after modifying based on the above.
The moonlights are no longer on, so it may have been a fluke somewhere.
Posted: Mon Oct 10, 2011 4:29 pm
by agentgreen
Ok, so, now I see why the MH was off, something is triggering the OverHeatShutOff, but I can't figure out what. My heaters and MH's are masked off right now because the controller thinks I've over heated.
In Client Suite, if I refresh the memory settings, Overheat is set to 150. In my PDE, I have the OverHeat probe set to Temp1, which is my water temp probe. My water temp is below 80 degrees.
Is memory overwriting the PDE in this regard?
Posted: Mon Oct 10, 2011 4:32 pm
Use this:
  if (hour()>=21 || hour()<=8) // Turn Moonlights on/off
    ReefAngel.PWM.SetActinic(0);
    ReefAngel.PWM.SetDaylight(0);
The reason they were on was probably because you forgot to turn them off when not within the time schedule you had.
Posted: Mon Oct 10, 2011 4:34 pm
Try changing the temperature to something else. I was testing your code and set it to 83 through the Client. Then with my hands I held the probe to increase the temperature and the ports went off, indicating that it was working as intended.
I only had that one probe in my tests, though... Not that it should influence the results.
Posted: Mon Oct 10, 2011 4:36 pm
by agentgreen
rimai wrote:Try changing the temperature to something else. I was testing your code and set it to 83 through the Client. Then with my hands I held the probe to increase the temperature and the ports went off, indicating that it was working as intended.
I just set the temp to 95 from the client and cleared the over heat warning. Lights came on for a couple seconds, and now are still masked off. Strange...
Posted: Mon Oct 10, 2011 4:39 pm
by agentgreen
rimai wrote:Use this:
I actually had this code setup previously and I think it was working. However, at the same time the controller was locking up on me every couple of hours. I removed the above loop and it resolved the lock ups. It could have been something else, but I attributed it to the loop.
Let's see what happens this time.
Posted: Mon Oct 10, 2011 4:45 pm
What happens if you use joystick and navigate to clear overheat?
Posted: Mon Oct 10, 2011 4:47 pm
by agentgreen
rimai wrote:What happens if you use joystick and navigate to clear overheat?
The lights and heaters go unmasked, the lights come on for about 10 seconds, then go off again, and in the client I see that they are masked off.
Posted: Mon Oct 10, 2011 5:04 pm
Beats me, man...
I got the same code and this behavior doesn't happen.
Can you use the update utility to download the latest code??
http://www.reefangel.com/update/
I'm running on .18
Posted: Mon Oct 10, 2011 5:12 pm
by dmolton
What happens if you remove the overheat line all together and re-upload?
Posted: Mon Oct 10, 2011 5:17 pm
by agentgreen
rimai wrote:Beats me, man...
I'm running on .18
I'm running .18 as well.
dmolton wrote:What happens if you remove the overheat line all together and re-upload?
I'm going to comment it out for now, with the alerting setup now, I can manually turn off stuff if I notice it gets hot.
For now I just want to stabilize the controller, so I'll figure this one out later.
