Problems uploading
Posted: Mon Jul 01, 2013 9:42 pm
Hi. I've owned a Reef Angel Plus for a while now but I've started having problems uploading recently. At this time, I'm not even trying anything fancy, just using the Wizard. Below is the code I tried uploading and the error I received. I had the error on OS X and WIN 7. Any ideas?
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit;
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardLights( Port1,12,0,19,0 );
ReefAngel.StandardLights( Port2,12,0,19,0 );
ReefAngel.StandardLights( Port3,11,30,19,30 );
ReefAngel.StandardHeater( Port4,751,761 );
ReefAngel.WavemakerRandom( Port5,60,100 );
ReefAngel.Wavemaker( Port6,60 );
ReefAngel.Portal( "Jeepstr455" );
Watchdog Timer
Version Menu
Wifi Attachment
Simple Menu
Binary sketch size: 32,752 bytes (of a 258,048 byte maximum)
avrdude: verification error, first mismatch at byte 0x0000
0x05 != 0xe2
avrdude: verification error; content mismatch
