Problems uploading
Jeepstr455
Problems uploading
Post by Jeepstr455 »
Hi. I've owned a Reef Angel Plus for a while now but I've started having problems uploading recently. At this time, I'm not even trying anything fancy, just using the Wizard. Below is the code I tried uploading and the error I received. I had the error on OS X and WIN 7. Any ideas?
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <Humidity.h>
#include <DCPump.h>
#include <ReefAngel.h>
    ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit;
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardLights( Port1,12,0,19,0 );
    ReefAngel.StandardLights( Port2,12,0,19,0 );
    ReefAngel.StandardLights( Port3,11,30,19,30 );
    ReefAngel.StandardHeater( Port4,751,761 );
    ReefAngel.WavemakerRandom( Port5,60,100 );
    ReefAngel.Wavemaker( Port6,60 );
    ReefAngel.Portal( "Jeepstr455" );
Watchdog Timer
Version Menu
Wifi Attachment
Simple Menu
Binary sketch size: 32,752 bytes (of a 258,048 byte maximum)
avrdude: verification error, first mismatch at byte 0x0000
0x05 != 0xe2
avrdude: verification error; content mismatch
Re: Problems uploading
I'm assuming you have RA+, right?
Does it happen everytime?
Jeepstr455
I do have the RA+ and it happens every time on both my Mac OS X and Windows 7 computers. It worked fine for a year and then when I tried make some changes the other day, it started giving me problems.
It could be two things: USB cable or head unit.
PM me if you would like to send it back for analysis.
Jeepstr455
The forum will not let me PM. I would like to send it in but need the details on what to ship, where to ship, any costs, etc.
Post a couple more times :)
