Help. 90% of my probes are not registering.
Posted: Fri Aug 16, 2013 5:59 pm
I rearranged my Temp probes becuase I realized that they were in the wrong ports and labeled wrong and everything was fine after that, but about 30 min later I lost all 3 temp probes and my salinity probe stopped registering.
On the head unit the 3 temp readings say error and the Salinity reads 6.
On everything else, Portal, Andriod App, RA Client and gadget the temps read 0 and Salinity reads 6. pH is fine on everything and everything else seems to be functioning properly.
I rebooted with no luck.
I reloaded the original code and then my code and still the same results.
What could have happened and how can I fix it?
Please Help.
Thanks you very much.
Please Help.
