Tidal Swell and Nutrient Transport sequence WP25
Posted: Tue Nov 26, 2013 6:40 pm
by lmolenmaker
Hi guys,
Can anybody tell me what the sequence is for the modes: A. Tidal Swell and B. Nutrient Export.
I am especially interested in the minimum speed % in the sequence as my WP25 shuts of at 20%.
I noticed that when I selected Nutrient transport the pump goes first through a pulsing sequence for an hour or so and then shuts down for a certain time. (I didn't time it).
If somewhere in the sequence the speed goes below 20%, is it possible for me to change that minimum speed?
Or do I need the whole code (modified with the minimum speed) in the "Custom code" section?
Hope you guys can help me out here.
Leslie
Re: Tidal Swell and Nutrient Transport sequence WP25
Posted: Tue Nov 26, 2013 7:16 pm
The DCPump Class will always set the min speed to zero.
Here is where it is set in the libraries:
https://github.com/reefangel/Libraries/ ... l.cpp#L295
If you use the dimming channels directly and use the NutrientTransportMode() function, you can set the min speed, but there is also a bug identified by another user:
http://forum.reefangel.com/viewtopic.php?p=33468#p33468
This is due to the fact that the function was reused from the vortech pump waveform and it uses 0% as a start of the parabola.
Doesn't the pump go back running when it goes past 20%?
Posted: Tue Nov 26, 2013 8:25 pm
by lmolenmaker
Yes, it switches back on. I just noticed that it switches off once a while, so I assumed that the minimum speed is below 20% somewhere.
As for the link you sent me, do I need to paste those 4 lines in the custom code section and disable the internal memory use and change the "0" into 20 ?
Thanks in advance
Posted: Tue Nov 26, 2013 9:15 pm
No, it wouldn't work.
Just like the graph in the other post, you can see that the function goes to zero when the parabola starts.
Posted: Wed Nov 27, 2013 10:13 pm
by lmolenmaker
Thanks Roberto.
Can you explain what a Tidal Swell does and what is the minimum speed% ?
Thanks in advance.
Leslie
Posted: Thu Nov 28, 2013 10:03 am
Tidal Swell is another mode with got from the Vortech pumps
http://ecotechmarine.com/ecosmart/vorte ... art-modes/
