will wave maker work for a single pump
Posted: Thu Nov 17, 2011 7:25 am
by jemw
I only want to have one pump using the wavemaker function. Are there any restrictions I should be aware of?
Re: will wave maker work for a single pump
Posted: Thu Nov 17, 2011 8:35 am
Nope. You can use just one :)
Posted: Thu Nov 17, 2011 9:00 am
by wolfador
will it actually make waves? I have a korelia nano 240 on my 10g would that work? At least until I get an MP10 ;)
Posted: Thu Nov 17, 2011 9:10 am
It doesn't make waves... :(
I've had nothing but problem with koralias. They seem to spin backwards and become weaker and weaker. I finally gave up, threw them in the garbage and bought vortechs.
Still use koralias though... Bought 2 new ones, but in always on mode.
They have not nearly the same flow as vortech for the size.
Mine are 3 times bigger inside the tank, but 10 times cheaper too.
Posted: Thu Nov 17, 2011 5:45 pm
by psyrob
Just to give my experience with Korlia's...I have the Evos 1050s and they have fixed those issues Roberto talks about...they are designed for wavemakers, but that really means just "on/off"...only controllable pumps can actually make "waves", and by controllable, that means pumps that can vary their speed, ramping up then ramping down, or those pumps that are designed for rapid on off (like a second or less, like in a Tunze wavebox). Koralia's are just not designed that way (except for their controllable ones). I use the Evos on the wavemaker function and they have worked flawlessly for the past three months...FWIW
Posted: Fri Nov 18, 2011 10:43 pm
by chase
I've been using two Hydor Koralia Evolution 750's on alternating 15-30sec cycles for several months without any issues. They do not generate 'waves', but I noticied a huge difference in LPS extension when running them on alternating cycles instead of always on.
Posted: Sun Nov 27, 2011 6:53 am
by ruckusman
Do you use the vortech system to run your pumps or your reef angel?
Posted: Sun Nov 27, 2011 9:28 am
I personally have both.
I use 2 Vortech and 2 Koralias.
All 4 can be controlled by Reef Angel, though the Koralias are just on/off and Vortech can have speed control.
Posted: Mon Dec 19, 2011 5:20 pm
by chase
ruckusman wrote:Do you use the vortech system to run your pumps or your reef angel?
I use the RA to control them.
