Float switch and pump
Posted: Wed Oct 08, 2014 11:54 am
by sfortin
Can Iget help with a code? I have a float switch right now in my aqua on the first floor and my sump is in the basement. when water rise in my aqua because a snail went in my pipe going down. the float switch stop my pump until i'm back and start it again manualy. Right it is the black box you see in the pic doing the job but every time i feed i have to go hit the reset button to re-start the pump
, so i cant use the feed mode!! Now how can i do that with RA?
Re: Float switch and pump
Posted: Wed Oct 08, 2014 2:11 pm
Try this:
if (ReefAngel.LowATO.IsActive()) ReefAngel.Relay.Override(Port8,0);
This assumes you are using the LowATO port for your float switch and Port8 for your return pump.
If the float switch is triggered, it will override Port8 to Off and you can clear the override with the Portal or smartphone app after you inspect and know what is wrong.
Posted: Wed Oct 08, 2014 2:19 pm
by sfortin
And we insert the code between wich line?
Posted: Wed Oct 08, 2014 2:20 pm
in the custom section of loop()
Posted: Wed Oct 08, 2014 2:30 pm
by sfortin
Thanks so so much
Posted: Wed Oct 08, 2014 3:25 pm
by sfortin
doesnt seem to work.
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port5Bit | Port7Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardLights( Port5,21,0,7,0 );
ReefAngel.StandardHeater( Port7,755,765 );
ReefAngel.Portal( "sfortin" );
Posted: Wed Oct 08, 2014 3:35 pm
by sfortin
oupsss it is working but the pump try to start back when i push the activate on my phone but for about half of a second and stop. it's just like trigering. :?
Posted: Wed Oct 08, 2014 3:47 pm
by sfortin
Jump to fast on conclusion. It is working super fine my float was defect....
Super service Roberto i'm going to talk of you on my french Québec forum because a lot of my friends are scare to buy because of service (open source) and because of language difference....
Posted: Wed Oct 08, 2014 4:10 pm
Awesome!! :)
Posted: Thu Jan 01, 2015 3:15 pm
by sfortin
Now i have another problem..everything was working super fine and now my pump keep stoping for no reason. Sometime it works for one minute and stop. i start it back and work for 10 minutes or 20 or 5 alway different. Took it from port 8 to port 7 and work for about 24 hours and now doing the same thing it was on port 7?????
Posted: Thu Jan 01, 2015 3:28 pm
When the pump stops, does that port show red in the screen display?
Posted: Thu Jan 01, 2015 3:33 pm
by sfortin
No it is black
Posted: Thu Jan 01, 2015 3:38 pm
Black?
It is supposed to be green or red.
I'm talking about the port 7 that you have your pump connected to.
Posted: Thu Jan 01, 2015 3:39 pm
by sfortin
Yes green
Posted: Thu Jan 01, 2015 3:40 pm
Was it showing green when the pump was off?
Posted: Thu Jan 01, 2015 3:46 pm
by sfortin
Yes it was
Posted: Thu Jan 01, 2015 3:50 pm
Try placing a lamp in there.
Does it do the same thing?
Could it be the pump itself?
Posted: Thu Jan 01, 2015 3:51 pm
by sfortin
I'll try but if i unplug the pump i hear the relay flikering
Posted: Thu Jan 01, 2015 3:54 pm
Did you check for any water damage in the head unit, svga cable or relay box?
Posted: Thu Jan 01, 2015 3:56 pm
by sfortin
No water went there at all it is on my basement wall
Posted: Thu Jan 01, 2015 4:17 pm
by sfortin
Just ordered a new module with disp.....
