dosing pump
Posted: Mon Dec 12, 2011 8:08 pm
by wijigong
if the dosing pump is able to push water 30inch up
i dont have sump
i think to use the dosing pump for water change
i think to change 500ml each day on the week
the dosimg pump is under the tank approximate 30inch under the top off the tank
Re: dosing pump
Posted: Mon Dec 12, 2011 10:13 pm
It can pump 30in of head, but you would wear off the motor if you try to use it for this purpose.
Re: dosing pump
Posted: Tue Dec 13, 2011 11:23 am
by tkeracer619
Look into a reeffiller dual head pump. It seems to be the best pump for autochanges.
