dosing pump
wijigong
dosing pump
Post by wijigong »
if the dosing pump is able to push water 30inch up
i dont have sump
i think to use the dosing pump for water change
i think to change 500ml each day on the week
the dosimg pump is under the tank approximate 30inch under the top off the tank
Re: dosing pump
It can pump 30in of head, but you would wear off the motor if you try to use it for this purpose.
tkeracer619
Re: dosing pump
Post by tkeracer619 »
Look into a reeffiller dual head pump. It seems to be the best pump for autochanges.
