Server Migration 12-17-2025
Posted: Wed Dec 10, 2025 5:08 pm
Dear Reef Angel Users,
We would like to inform you the hosting company is forcing us to move to a new server platform, the good news is this will improve speed and performance, the bad news is we will be receiving a new public IP which will affect some users accessing the controller remotely. We plan to do the migration on 12/17/25 at 7:00 AM UTC.
Please expect the migration to take up to 2 Hours.
During this time the Forum, Uapp, and Webwizard will be unavailable.
Instructions for each device below on how to migrate.
Star Users
If you are currently using a Star I have modified the Libraries to use DNS so if you have uploaded your code within the last month your controller will automatically migrate to the new server.
To verify this: In the Uapp side menu click get Libraries version, if it responds with 1.1.4 you are up to date and you do not need to do anything.
If it still says Version 1.1.3. Just reupload your code to your controller and it will update to the newest version.
Plus with Cloud Wifi Attachment
No changes are needed the cloud Wifi Module will automatically switch to the new server.
Plus with Wifi Attachment
I recommenced waiting to do this until the day before the migration or after the migration.
If you have the Orignal Wifi Attachment you will need to download Tera Team and the updatewifi zip file below.
You need to decompress the zip file.
Open the .ttl file in notepad or any other text editor.
Change the SSID and passphrase.
Save the file.
Use Tera Term and go to menu Control->Macro
Browse to the .ttl file you just edited.
It should configure the module at the end of the process.
If you don't get anything in the screen, you will need to change the baud rate before you open the .ttl file.
Go to menu Setup->Serial port and choose 57600 baud and then go to menu Control->Macro to open the .ttl file.
Tera Team Download: https://github.com/TeraTermProject/tera ... rm-5.3.exe
Wifi Attachement Firmware: firmware/updatewifi.zip
Star Users
Save the file.
