Server Migration 12-17-2025
Important announcements for the Reef Angel Controller
brennyn21
Post by brennyn21 »
Dear Reef Angel Users,
We would like to inform you the hosting company is forcing us to move to a new server platform, the good news is this will improve speed and performance, the bad news is we will be receiving a new public IP which will affect some users accessing the controller remotely. We plan to do the migration on 12/17/25 at 7:00 AM UTC.
Please expect the migration to take up to 2 Hours.
During this time the Forum, Uapp, and Webwizard will be unavailable.
Instructions for each device below on how to migrate.
Star Users
If you are currently using a Star I have modified the Libraries to use DNS so if you have uploaded your code within the last month your controller will automatically migrate to the new server.
To verify this: In the Uapp side menu click get Libraries version, if it responds with 1.1.4 you are up to date and you do not need to do anything.
If it still says Version 1.1.3. Just reupload your code to your controller and it will update to the newest version.
Plus with Cloud Wifi Attachment
No changes are needed the cloud Wifi Module will automatically switch to the new server.
Plus with Wifi Attachment
I recommenced waiting to do this until the day before the migration or after the migration.
If you have the Orignal Wifi Attachment you will need to download Tera Team and the updatewifi zip file below.
You need to decompress the zip file.
Open the .ttl file in notepad or any other text editor.
Change the SSID and passphrase.
Save the file.
Use Tera Term and go to menu Control->Macro
Browse to the .ttl file you just edited.
It should configure the module at the end of the process.
If you don't get anything in the screen, you will need to change the baud rate before you open the .ttl file.
Go to menu Setup->Serial port and choose 57600 baud and then go to menu Control->Macro to open the .ttl file.
Tera Team Download: https://github.com/TeraTermProject/tera ... rm-5.3.exe
Wifi Attachement Firmware: firmware/updatewifi.zip
Sincerely, Brennyn
brennyn21
Re: Server Migration 12-17-2025
Post by brennyn21 »
The server migration has been completed. If you have trouble connecting please reboot your controller, or if you have the Wifi Attachment with the Plus update your Wifi Attachment.
Thank you for your patience.
Sincerely, Brennyn
Reefology
Post by Reefology »
Happy new year Brennyn, hoping you are well.
I'm having trouble connecting to the cloud and wondering if this is an issue with the new server? My cloud status connection keeps dropping (shows "disconnected" on the head unit but "connected" on the UAPP) and I have to reboot my star to reestablish a connection.
2 questions:
1. is there a way to force a connection so I can view current parameters or control relays via the UAPP?
2. is there a way to control my RA within my local network without having to go through the cloud? This would make it useable even if/when the server was down. I do have Home Assistant with MQTT Mosquito Broker setup but not sure how to set it up viewtopic.php?p=59559&hilit=mqtt#p59559
BTW, still unable to use Alexa
Reefology
Post by Reefology »
FYI, I tried to force update from the Uapp wizard and that failed as well.
brennyn21
Post by brennyn21 »
Hi Reefology, sorry for the delay, and also happy new years!
Are you still having the connections drop on the Star? If the connection ever does drop it should automatically reconnect, but if it fails to reconnect then it will wait longer in-between reconnection attempts.
If you wanted to use your own MQTT server you would have to recompile the code locally and then the Uapp wouldn't work sadly.
As for local control, in the android app you can add the IP address of your Star and control it locally, then you don't have to rely on any server infrastructure as the App communicates directly to the Reef Angel. Its only supported in the IOS App, and Android App, as its not possible to do it on the Web App version.
The Uapp isn't in the App stores yet as its hasn't been approved, but I would assume it will be soon.
I also resubmitted the Alexa skill to include Canada Region so can you look again and see if you are able to see it now?
Sincerely, Brennyn
