how do i use the reading of temp probe 2 in a "if" statement like:
if (tempprobe2 <= 760)
do something
and while im posting... will this work to have moonlights on from the end of standardlights until 3am? basically i want to have the moonlights go off at 3am.
if ( hour() >= 20 && hour () <= 3 )
ReefAngel.MoonLights(Port2); // Moonlights or Refugium
using temp probes for other code.
Re: using temp probes for other code.
if (ReefAngel.Params.Temp[T2_PROBE]<= 760)
You need to use ||, which means or.
ReefAngel.Relay.Off(Port2);
Meshmez
awesome!
Thanks for both posts!
