Analog Dimming & MOONPHASE ?
Re: Analog Dimming & MOONPHASE ?
Will this do the trick? I was getting an error. So I added a time-out value
    InternalMemory.OverheatTemp_write( 860 );
    ReefAngel.Relay.On(Port3);
    ReefAngel.Relay.On(Port4);
    ReefAngel.Relay.On(Port7);
    ReefAngel.Relay.On(Port8);
    ReefAngel.StandardLights( Port1,19,0,6,30 );
    ReefAngel.StandardHeater( Port4,740,770 );
    ReefAngel.StandardLights( Port7,6,0,20,0 );
    ReefAngel.StandardLights( Port8,7,0,19,0 );
    ReefAngel.Wavemaker1(Port5);
    ReefAngel.Wavemaker2(Port6);
    ReefAngel.PWM.SetDaylight( PWMParabola(7,5,19,0,0,85,0) );
    ReefAngel.PWM.SetActinic( PWMParabola(6,5,21,0,0,85,0) );
    ReefAngel.SingleATOHigh(60);
    pinMode(lowATOPin,OUTPUT);
    analogWrite(lowATOPin,(int)MoonPhase()*2.55);
    // This sends all the data to the portal
    // Do not add any custom code that changes any relay status after this line
    // The only code after this line should be the ShowInterface function
    ReefAngel.Portal("DrewPalmer04", ********");
I just saw you have all settings in the code, so it is easier for you to use this instead then:
ReefAngel.SingleATO( false,Port2,60,0 );
You can change the Port2 to whatever port you have your ATO pump plugged into.
Great got it uploaded...this should allow ATOlow to dim with the moonphase now? between 0-5VDC?
yeah :)
I'm still getting that flash...i wonder why? The moon being 89% right now (Waxing Gibbous) I'm not sure how to tell if it's dimmed or not (I guess Voltimeter)...
Another thing..I have the LEDs plugged in now...is there anyway to set a schedule for on/off phrams? Or should I just leave them on all the time?
Yes, a meter works.
I think you already have it setup to turn on/off:
The moon lights are powered by ony the 0-5vdc output of that low ATO port. I guess there is no way to tell it to follow 0-5v moon phase but reach 0 at a certain time of the day?
What I mean is I'm not using a dimmable driver for the LEDs...just resistors for the inflow of the 0-5VDC power. ;)
Solved the flashing issue: This way the pin lowATO is set up as output...then loops moonphase
    ReefAngel.Portal("DrewPalmer04", "********");
Would still like to figure out how to make them turn off at 0600 until 2100 from the output pin of lowATO
Try this:
if (hour>=21 || hour()<6)
    analogWrite(lowATOPin,0);
RA_052912_1615custom2.cpp: In function 'void loop()':
RA_052912_1615custom2:88: error: invalid operands of types '<unresolved overloaded function type>' and 'int' to binary 'operator>='
Typo :( Sorry
if (hour()>=21 || hour()<6)
This one did it! :)
if (hour()>=2100 || hour()<0600)
Roberto. Sorry but still no out put from the lowATO. I have the code you posted above. Any idea?
Sorry, the code you posted is wrong.
You will never get hour to be 2100.
We only have 24 hours.
What I meant to say was I returned to your code at the top of this page. Nothing happens.
I'm going to try to use a if else command to just use my meanwell drivers to use Pwm parabola until 8pm to 6am then "else" to moon phase ? Possible?
Fixed..working perfect...confirmed:
if (hour()>=21 && hour()<6)
