Relay Not Responding
Over the weekend I installed my controller, two relays, IO module, and so on, up to the tank for production. Prior to then I was testing with a simple lamp to verify functionality. All of the relays on the main relay module work fine. The expansion relay would not turn my powerheads back on when the feeding mode ended. Nothing except unplugging the power to the expansion relay box and plugging it back in would wake up the powerhead relays on the expansion box. At first I thought the issue was with my code, such as a misconfigured feeding mode function. However, the powerheads (and some other relays on the expansion box) do not turn back on via the portal or android app, and the display on the controller properly indicates which ports SHOULD be on/off. Is there a limitation as to what kind of loads can be plugged into the relays? I suspect I have something plugged in to the expansion box that is preventing its relays from operating properly, though I doubt the powerheads draw many amps. Testing with a simple incandescent lamp prior to installation verified that my code functions, and that the hardware works.
What is plugged in to expansion relay, and results of toggling power via android app/water change mode/portal:
Port 1: 2x 150w metal halides, analogue ballasts <--- did not test extensively, but power toggled on/off properly about three times
Port 2: 1x 250w heater <--- did not test
Port 3: Actinics, 384w <--- power toggles properly each time
Port 4: Two powerheads, probably 10w each<--- power will not turn on after toggling off. Must reset via power to box
Port 5: Topoff pump, 3w <--- power will toggle sometimes, not every time
Port 6: Topoff pump, 3w <--- power will toggle sometimes, not every time
Port 7: Two powerheads, probably 10w each <--- power will not turn on after toggling off. Must reset via power to box
Port 8: Skimmer, 50w <--- power toggles properly each time
Re: Relay Not Responding
You should be fine with that equipment.
So, what you are saying is that you tested the hardware and code before installing and everything was working, but when you connected your equipment, this behavior started happening?
Yes, exactly. Have you seen this happen before?
Yeah same here just tested and ports 1,4,6,7 on expansion relay does same, will turn off through phone app and portal, but when turned back on says its on but is not.......
When you do that with one port, can you still turn off a second port and so on for all ports?
If you go through all ports, do you end up with all ports off that you can't turn on?
Do they work fine if they are left on auto mode?
All of mine on the expansion relay are set to always on, and if you turn them off manually via portal or phone app then turn them back on and they show on in both phone and portal app they are not. also while testing mentioned ports that went off and stay off will not power back up until relay power is cycled. Like i said all mine on expansion are set to always on and they do stay on always its just until you manually cycle them, then they wont come back on.
I also tested each port with a simple led night lite as Btorrenga did almost the same but I definately dont think it is a load issue because an led nitelite doesnt draw hardly anything, so I think it is something else. Hopefully Roberto can figure this out...
Perhaps the most recent library update? I did my extensive testing under 0.9.7 or 0.9.8.CASPAR wrote:I also tested each port with a simple led night lite as Btorrenga did almost the same but I definately dont think it is a load issue because an led nitelite doesnt draw hardly anything, so I think it is something else. Hopefully Roberto can figure this out...
Interesting, 0.9.6 was the version with the portal XML issue, I think. I did my testing under the library version that had the XML problem preventing the portal from working.
I just ran through the feeding mode which is configured to turn off two relays on the expansion relay. I did not manually exit the feeding mode. Both relays turned on perfectly when feeding mode timed out. Then I entered feeding mode again and manually cancelled it. Only one of the two relays turned on after manually exiting feeding mode.
I then entered feeding mode again while one of the relays was improperly off and allowed feeding mode to timeout. Both relays properly turned back on after feeding mode timed out.
Humm, that's very interesting information.
This sounds definitely a bug in the libraries.
I'll look into it.
Thanks a lot for the troubleshooting and information to narrow down the possible causes![Smile :)](./images/smilies/icon_e_smile.gif)
I'll look into it.
Any ideas yet roberto? I am using 0.9.6 lib file do i need to change it, really need to get this working
I can't seem to be able to replicate the problem.
Can you try updating the libraries to 0.9.9?
I just ran feeding mode two more times... First time one of the two relays came back on after timeout, second time neither relay came back on after timeout. That kills my theory that timeout restore relays fine.
Browse the controller with http://ipaddress:2000/r99
It should give you some XML data.
Can you get this XML data before you go into feed mode, during and after?
Other than feed mode, does it work as expected? As in, for your Box1_Port 2 (heater), does it turn on/off according to the temperature settings you chose?
I pulled the power on the main relay, plugged it back in, then pulled power on the expansion relay and plugged that back in.
Here is /r99 output after that reboot:
I then waited for the metalhalides to turn back on. Here is the /r99 output when the metal halides turned on:
Then I entered feeding mode, and ports 4 and 7 on the expansion relay properly turned off:
Feeding mode then timed out, and expansion relay port 7 properly came back on, expansion relay port 4 did not:
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<RA>
<T1>800</T1>
<T2>802</T2>
<T3>753</T3>
<PH>811</PH>
<R>132</R>
<RON>0</RON>
<ROFF>255</ROFF>
<R1>204</R1>
<RON1>0</RON1>
<ROFF1>255</ROFF1>
<R2>0</R2>
<RON2>0</RON2>
<ROFF2>255</ROFF2>
<R3>0</R3>
<RON3>0</RON3>
<ROFF3>255</ROFF3>
<R4>0</R4>
<RON4>0</RON4>
<ROFF4>255</ROFF4>
<R5>0</R5>
<RON5>0</RON5>
<ROFF5>255</ROFF5>
<R6>0</R6>
<RON6>0</RON6>
<ROFF6>255</ROFF6>
<R7>0</R7>
<RON7>0</RON7>
<ROFF7>255</ROFF7>
<R8>0</R8>
<RON8>0</RON8>
<ROFF8>255</ROFF8>
<ATOLOW>1</ATOLOW>
<ATOHIGH>1</ATOHIGH>
<EM>32</EM>
<REM>1</REM>
<PWMA>0</PWMA>
<PWMD>0</PWMD>
<IO>0</IO>
<C0>0</C0>
<C1>0</C1>
<C2>0</C2>
<C3>0</C3>
<C4>0</C4>
<C5>190</C5>
<C6>0</C6>
<C7>0</C7>
</RA>
<RA>
<T1>800</T1>
<T2>800</T2>
<T3>748</T3>
<PH>810</PH>
<R>140</R>
<RON>0</RON>
<ROFF>255</ROFF>
<R1>205</R1>
<RON1>0</RON1>
<ROFF1>255</ROFF1>
<R2>0</R2>
<RON2>0</RON2>
<ROFF2>255</ROFF2>
<R3>0</R3>
<RON3>0</RON3>
<ROFF3>255</ROFF3>
<R4>0</R4>
<RON4>0</RON4>
<ROFF4>255</ROFF4>
<R5>0</R5>
<RON5>0</RON5>
<ROFF5>255</ROFF5>
<R6>0</R6>
<RON6>0</RON6>
<ROFF6>255</ROFF6>
<R7>0</R7>
<RON7>0</RON7>
<ROFF7>255</ROFF7>
<R8>0</R8>
<RON8>0</RON8>
<ROFF8>255</ROFF8>
<ATOLOW>1</ATOLOW>
<EM>32</EM>
<REM>1</REM>
<PWMA>0</PWMA>
<PWMD>0</PWMD>
<IO>0</IO>
<C0>0</C0>
<C1>0</C1>
<C2>0</C2>
<C3>0</C3>
<C4>0</C4>
<C5>190</C5>
<C6>0</C6>
<C7>0</C7>
</RA>
<RA>
<T1>800</T1>
<T2>800</T2>
<T3>748</T3>
<PH>809</PH>
<R>140</R>
<RON>0</RON>
<ROFF>79</ROFF>
<R1>205</R1>
<RON1>0</RON1>
<ROFF1>183</ROFF1>
<R2>0</R2>
<RON2>0</RON2>
<ROFF2>255</ROFF2>
<R3>0</R3>
<RON3>0</RON3>
<ROFF3>255</ROFF3>
<R4>0</R4>
<RON4>0</RON4>
<ROFF4>255</ROFF4>
<R5>0</R5>
<RON5>0</RON5>
<ROFF5>255</ROFF5>
<R6>0</R6>
<RON6>0</RON6>
<ROFF6>255</ROFF6>
<R7>0</R7>
<RON7>0</RON7>
<ROFF7>255</ROFF7>
<R8>0</R8>
<RON8>0</RON8>
<ROFF8>255</ROFF8>
<ATOLOW>1</ATOLOW>
<EM>32</EM>
<REM>1</REM>
<PWMA>0</PWMA>
<PWMD>0</PWMD>
<IO>0</IO>
<C0>0</C0>
<C1>0</C1>
<C2>0</C2>
<C3>0</C3>
<C4>0</C4>
<C5>190</C5>
<C6>0</C6>
<C7>0</C7>
</RA>
<RA>
<T1>798</T1>
<T2>798</T2>
<T3>744</T3>
<PH>810</PH>
<R>140</R>
<RON>0</RON>
<ROFF>255</ROFF>
<R1>205</R1>
<RON1>0</RON1>
<ROFF1>255</ROFF1>
<R2>0</R2>
<RON2>0</RON2>
<ROFF2>255</ROFF2>
<R3>0</R3>
<RON3>0</RON3>
<ROFF3>255</ROFF3>
<R4>0</R4>
<RON4>0</RON4>
<ROFF4>255</ROFF4>
<R5>0</R5>
<RON5>0</RON5>
<ROFF5>255</ROFF5>
<R6>0</R6>
<RON6>0</RON6>
<ROFF6>255</ROFF6>
<R7>0</R7>
<RON7>0</RON7>
<ROFF7>255</ROFF7>
<R8>0</R8>
<RON8>0</RON8>
<ROFF8>255</ROFF8>
<ATOLOW>1</ATOLOW>
<EM>32</EM>
<REM>1</REM>
<PWMA>0</PWMA>
<PWMD>0</PWMD>
<IO>0</IO>
<C0>0</C0>
<C1>0</C1>
<C2>0</C2>
<C3>0</C3>
<C4>0</C4>
<C5>190</C5>
<C6>0</C6>
<C7>0</C7>
</RA>
Everything looks good in there.
What happens if you mode port4 and port 7 to another port and change the code accordingly?
Ok, I swapped expansion ports 3 with 4, and swapped expansion ports 7 with 8, so that now feeding mode should turn off/on expansion ports 3 and 8:
Here is /r99 after pulling power on each relay:
Entering feeding mode did not work properly, since expansion port 8 turned off but expansion port 3 did not:
Upon feeding mode timeout both expansion ports 3 and 8 properly turned on:
#define DisplayImages
#define SetupExtras
#define OverheatSetup
#define DateTimeSetup
#define VersionMenu
#define wifi
#define SaveRelayState
#define RelayExp
#define InstalledRelayExpansionModules 1
#define DosingPumpIntervalSetup
#define WDT
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 9
#define CUSTOM_MAIN
#define COLORS_PDE
#define ENABLE_ATO_LOGGING
#define ENABLE_EXCEED_FLAGS
#define IOEXPANSION
#define FONT_8x8
#define FONT_8x16
#define FONT_12x16
#define NUMBERS_8x8
#define NUMBERS_8x16
#define NUMBERS_12x16
#define NUMBERS_16x16
#define CUSTOM_VARIABLES
#include <avr/pgmspace.h>
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long buzzerinterval = 1000; // interval at which to sound buzzer (milliseconds)
long previousMillis = 0;
prog_char menu6_label[] PROGMEM = "Date / Time";
prog_char menu7_label[] PROGMEM = "Version";
prog_char menu8_label[] PROGMEM = "Turn ON/OFF Skimmer";
prog_char menu9_label[] PROGMEM = "Turn Off Skimmer";
menu4_label, menu5_label, menu6_label,
menu7_label, menu8_label, menu9_label
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.SetupDateTime();
void MenuEntry7()
ReefAngel.DisplayVersion();
void MenuEntry8()
ReefAngel.Relay.Toggle(Box1_Port8);
ReefAngel.Relay.Write();
void MenuEntry9()
ReefAngel.LCD.DrawDate(6, 119);
ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params);
// draw main relay
#ifdef RelayExp
// draw 1st expansion relay
ReefAngel.LCD.DrawOutletBox(12, 105, TempRelay);
#endif // RelayExp
// Change the 45 to adjust the horizontal position of the text
void CheckReservoirStatus(byte channel, byte pump)
if ( ReefAngel.IO.GetChannel(channel) )
// If empty, shutoff the port, trigger alert
ReefAngel.CustomVar[channel] = 1;
ReefAngel.Relay.Off(pump);
// If not empty, turn on the port, clear alert
ReefAngel.CustomVar[channel] = 0;
ReefAngel.Relay.On(pump);
void MyCustomATO(int ATOTimeout)
This function works as follows:
When it's time to topoff the system, we check the levels of each
of the three reservoirs. If a reservoir is empty, we set a custom
flag to indicate it's empty on the portal and we do not start that
pump. Otherwise, we clear the custom flag for the reservoir and
start the pump.
The function monitors the switch levels like normal.
Monitor the status of the reservoirs while topping off.
When the high switch is triggered (aka, finished topping off),
ALL ports are turned off regardless of status (doesn't hurt to do this).
If the timeout occurs, the LED light comes on and all ports are
turned off just like when we finish topping off.
unsigned long TempTimeout = ATOTimeout;
TempTimeout *= 1000;
if ( ReefAngel.LowATO.IsActive() && ( !ReefAngel.LowATO.IsTopping()) )
ReefAngel.LowATO.Timer = millis();
ReefAngel.LowATO.StartTopping();
// Check the level of each reservoir
// If empty, set the alert and don't start topping off
// otherwise if not empty, clear the alert and start topping
CheckReservoirStatus(0, Port5);
CheckReservoirStatus(1, Port6);
CheckReservoirStatus(2, Box1_Port5);
// Monitor levels while topping off, to prevent a reservoir from running dry
// Might need to remove this check here -- Nope, this seems to work fine.
if ( ReefAngel.LowATO.IsTopping() )
if ( ReefAngel.HighATO.IsActive() )
ReefAngel.LowATO.StopTopping(); // stop the low ato timer
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
ReefAngel.Relay.Off(Box1_Port5);
if ( (millis()-ReefAngel.LowATO.Timer > TempTimeout) && ReefAngel.LowATO.IsTopping() )
ReefAngel.LED.On();
#ifdef ENABLE_EXCEED_FLAGS
InternalMemory.write(ATO_Exceed_Flag, 1);
#endif // ENABLE_EXCEED_FLAGS
#ifdef ENABLE_ATO_LOGGING
// bump the counter if a timeout occurs
AtoEventCount++;
if ( AtoEventCount >= MAX_ATO_LOG_EVENTS ) { AtoEventCount = 0; }
#endif // ENABLE_ATO_LOGGING
// Initialize the custom menu
ReefAngel.FeedingModePortsE[0] = Port3Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port4Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit;
ReefAngel.LightsOnPortsE[0] = Port1Bit | Port3Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePortsE[0] = Port2Bit | Port4Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.On(Box1_Port3);
ReefAngel.Relay.On(Box1_Port8);
ReefAngel.StandardLights(Port1,23,0,2,0); // Moon lights on 23:00-02:00
ReefAngel.StandardHeater(Port2,780,790); // 800w heater on at 78.0, off at 79.0
ReefAngel.MHLights(Port4); // MH on 14:00-22:00, delay 15m if power fails
ReefAngel.StandardLights(Port7,21,0,13,0); // Sump lights on 21:00-13:00
ReefAngel.StandardLights(Port8,8,0,21,0); //Plant lights on 08:00-21:00
ReefAngel.MHLights(Box1_Port1); // MH on 14:00-22:00, delay 15m if power fails
ReefAngel.StandardHeater(Box1_Port2); // 250w heater on at 78.5, off at 79.0
ReefAngel.StandardLights(Box1_Port4); // Actinics on 13:00-23:00
//ATO function
MyCustomATO(InternalMemory.ATOTimeout_read());
//Notify when sump level is low
if ( ReefAngel.IO.GetChannel(4) )
ReefAngel.CustomVar[4]=1;
// If the sump level is about to cavitate the pumps, then sound the alarm
unsigned long currentMillis = millis();
if(currentMillis - previousMillis > buzzerinterval) {
// save the last time the buzzer turned on
previousMillis = currentMillis;
// if the buzzer is off turn it on and vice-versa:
if (ReefAngel.PWM.GetDaylightValue() == 0)
ReefAngel.PWM.SetDaylight(25);
ReefAngel.PWM.SetDaylight(0);
// Turn the buzzer off when the sump level is above cavitation levels
ReefAngel.CustomVar[4]=0;
//If the ATO float switch is stuck, and the topoff pump timeout flag is set, then set C5=1
ReefAngel.CustomVar[5]=InternalMemory.read(ATO_Exceed_Flag); //Note that this value should be either 0 or 1, but for some reason is 254 or 255.
//Vodka dosing
if ( ReefAngel.IO.GetChannel(3) ) //Check there is vodka in the reservoir
ReefAngel.Relay.Off(Box1_Port6); //If no vodka, then set a variable and turn off the port
ReefAngel.CustomVar[3]=1;
else //If there is vodka, then dose
ReefAngel.CustomVar[3]=0;
ReefAngel.DosingPumpRepeat1(Box1_Port6);
//Monitor the water level in the display
ReefAngel.CustomVar[6]=ReefAngel.IO.GetChannel(5);
ReefAngel.Portal("btorrenga");
<RA>
<T1>800</T1>
<T2>800</T2>
<T3>743</T3>
<PH>811</PH>
<R>68</R>
<RON>0</RON>
<ROFF>79</ROFF>
<R1>204</R1>
<RON1>0</RON1>
<ROFF1>123</ROFF1>
<R2>0</R2>
<RON2>0</RON2>
<ROFF2>255</ROFF2>
<R3>0</R3>
<RON3>0</RON3>
<ROFF3>255</ROFF3>
<R4>0</R4>
<RON4>0</RON4>
<ROFF4>255</ROFF4>
<R5>0</R5>
<RON5>0</RON5>
<ROFF5>255</ROFF5>
<R6>0</R6>
<RON6>0</RON6>
<ROFF6>255</ROFF6>
<R7>0</R7>
<RON7>0</RON7>
<ROFF7>255</ROFF7>
<R8>0</R8>
<RON8>0</RON8>
<ROFF8>255</ROFF8>
<ATOLOW>1</ATOLOW>
<EM>32</EM>
<REM>1</REM>
<PWMA>0</PWMA>
<PWMD>0</PWMD>
<IO>0</IO>
<C0>0</C0>
<C1>0</C1>
<C2>0</C2>
<C3>0</C3>
<C4>0</C4>
<C5>190</C5>
<C6>0</C6>
<C7>0</C7>
</RA>
<RA>
<T1>798</T1>
<T2>798</T2>
<T3>743</T3>
<PH>811</PH>
<R>68</R>
<RON>0</RON>
<ROFF>79</ROFF>
<R1>204</R1>
<RON1>0</RON1>
<ROFF1>123</ROFF1>
<R2>0</R2>
<RON2>0</RON2>
<ROFF2>255</ROFF2>
<R3>0</R3>
<RON3>0</RON3>
<ROFF3>255</ROFF3>
<R4>0</R4>
<RON4>0</RON4>
<ROFF4>255</ROFF4>
<R5>0</R5>
<RON5>0</RON5>
<ROFF5>255</ROFF5>
<R6>0</R6>
<RON6>0</RON6>
<ROFF6>255</ROFF6>
<R7>0</R7>
<RON7>0</RON7>
<ROFF7>255</ROFF7>
<R8>0</R8>
<RON8>0</RON8>
<ROFF8>255</ROFF8>
<ATOLOW>1</ATOLOW>
<EM>32</EM>
<REM>1</REM>
<PWMA>0</PWMA>
<PWMD>0</PWMD>
<IO>0</IO>
<C0>0</C0>
<C1>0</C1>
<C2>0</C2>
<C3>0</C3>
<C4>0</C4>
<C5>190</C5>
<C6>0</C6>
<C7>0</C7>
</RA>
<RA>
<T1>798</T1>
<T2>800</T2>
<T3>741</T3>
<PH>810</PH>
<R>68</R>
<RON>0</RON>
<ROFF>255</ROFF>
<R1>204</R1>
<RON1>0</RON1>
<ROFF1>255</ROFF1>
<R2>0</R2>
<RON2>0</RON2>
<ROFF2>255</ROFF2>
<R3>0</R3>
<RON3>0</RON3>
<ROFF3>255</ROFF3>
<R4>0</R4>
<RON4>0</RON4>
<ROFF4>255</ROFF4>
<R5>0</R5>
<RON5>0</RON5>
<ROFF5>255</ROFF5>
<R6>0</R6>
<RON6>0</RON6>
<ROFF6>255</ROFF6>
<R7>0</R7>
<RON7>0</RON7>
<ROFF7>255</ROFF7>
<R8>0</R8>
<RON8>0</RON8>
<ROFF8>255</ROFF8>
<ATOLOW>1</ATOLOW>
<EM>32</EM>
<REM>1</REM>
<PWMA>0</PWMA>
<PWMD>0</PWMD>
<IO>0</IO>
<C0>0</C0>
<C1>0</C1>
<C2>0</C2>
<C3>0</C3>
<C4>0</C4>
<C5>190</C5>
<C6>0</C6>
<C7>0</C7>
</RA>
I have two ports on the main relay and one on the expansion relay that run topoff pumps. The display properly indicates that all three ports turn on, but the port on the expansion relay does not actually energize.
I swapped boxes (what a pain). Here is r99 before entering feeding mode:
During feeding mode, both expansion relays 3 and 8 properly turned off:
After feeding mode timed out, and the ports properly turned on. Dammit:
I entered and exited feeding mode a few more times, worked flawlessly each time. So, what the heck is going on?
<RA>
<T1>782</T1>
<T2>784</T2>
<T3>750</T3>
<PH>800</PH>
<R>142</R>
<RON>0</RON>
<ROFF>255</ROFF>
<R1>207</R1>
<RON1>0</RON1>
<ROFF1>255</ROFF1>
<R2>0</R2>
<RON2>0</RON2>
<ROFF2>255</ROFF2>
<R3>0</R3>
<RON3>0</RON3>
<ROFF3>255</ROFF3>
<R4>0</R4>
<RON4>0</RON4>
<ROFF4>255</ROFF4>
<R5>0</R5>
<RON5>0</RON5>
<ROFF5>255</ROFF5>
<R6>0</R6>
<RON6>0</RON6>
<ROFF6>255</ROFF6>
<R7>0</R7>
<RON7>0</RON7>
<ROFF7>255</ROFF7>
<R8>0</R8>
<RON8>0</RON8>
<ROFF8>255</ROFF8>
<ATOLOW>1</ATOLOW>
<EM>32</EM>
<REM>1</REM>
<PWMA>0</PWMA>
<PWMD>0</PWMD>
<IO>0</IO>
<C0>0</C0>
<C1>0</C1>
<C2>0</C2>
<C3>0</C3>
<C4>0</C4>
<C5>190</C5>
<C6>0</C6>
<C7>0</C7>
</RA>
<RA>
<T1>784</T1>
<T2>782</T2>
<T3>750</T3>
<PH>799</PH>
<R>142</R>
<RON>0</RON>
<ROFF>79</ROFF>
<R1>207</R1>
<RON1>0</RON1>
<ROFF1>123</ROFF1>
<R2>0</R2>
<RON2>0</RON2>
<ROFF2>255</ROFF2>
<R3>0</R3>
<RON3>0</RON3>
<ROFF3>255</ROFF3>
<R4>0</R4>
<RON4>0</RON4>
<ROFF4>255</ROFF4>
<R5>0</R5>
<RON5>0</RON5>
<ROFF5>255</ROFF5>
<R6>0</R6>
<RON6>0</RON6>
<ROFF6>255</ROFF6>
<R7>0</R7>
<RON7>0</RON7>
<ROFF7>255</ROFF7>
<R8>0</R8>
<RON8>0</RON8>
<ROFF8>255</ROFF8>
<ATOLOW>1</ATOLOW>
<EM>32</EM>
<REM>1</REM>
<PWMA>0</PWMA>
<PWMD>0</PWMD>
<IO>0</IO>
<C0>0</C0>
<C1>0</C1>
<C2>0</C2>
<C3>0</C3>
<C4>0</C4>
<C5>190</C5>
<C6>0</C6>
<C7>0</C7>
</RA>
<RA>
<T1>784</T1>
<T2>784</T2>
<T3>752</T3>
<PH>799</PH>
<R>142</R>
<RON>0</RON>
<ROFF>255</ROFF>
<R1>207</R1>
<RON1>0</RON1>
<ROFF1>255</ROFF1>
<R2>0</R2>
<RON2>0</RON2>
<ROFF2>255</ROFF2>
<R3>0</R3>
<RON3>0</RON3>
<ROFF3>255</ROFF3>
<R4>0</R4>
<RON4>0</RON4>
<ROFF4>255</ROFF4>
<R5>0</R5>
<RON5>0</RON5>
<ROFF5>255</ROFF5>
<R6>0</R6>
<RON6>0</RON6>
<ROFF6>255</ROFF6>
<R7>0</R7>
<RON7>0</RON7>
<ROFF7>255</ROFF7>
<R8>0</R8>
<RON8>0</RON8>
<ROFF8>255</ROFF8>
<ATOLOW>1</ATOLOW>
<EM>32</EM>
<REM>1</REM>
<PWMA>0</PWMA>
<PWMD>0</PWMD>
<IO>0</IO>
<C0>0</C0>
<C1>0</C1>
<C2>0</C2>
<C3>0</C3>
<C4>0</C4>
<C5>190</C5>
<C6>0</C6>
<C7>0</C7>
</RA>
Strange huh?
I dunno either. I'm going along with what you are finding out.
What about the main box? Is it work fine too?
There was one case in the past where stuff wasn't working either, but even swapping boxes didn't fix the issue.
The only thing that made it work without a hickup was to swap out all the equipment from the expansion box to main box and the equipment from main box to the expansion box.
I never couldn't figure that one out...
But it worked.
I think it was something to do with load like you suspected on a previous post.
I just can't wrap my head around it because load "shouldn't" have anything to do with it.
![Sad :(](./images/smilies/icon_e_sad.gif)
I manually toggled each port.
Main relay:
1 ok
2 ok
3 Turned off ok, will not come back on. Is set to always be on as a pump.
4 ok
5 ok
6 ok
7 ok
8 ok
Expansion relay:
1 ok
2 ok
3 ok
4 Completely unresponsive, is stuck on as my actinic lights.
5 ok
6 ok
7 ok
8 ok
Main relay:
1 ok
2 ok
4 ok
5 ok
6 ok
7 ok
8 ok
Expansion relay:
1 ok
2 ok
3 ok
5 ok
6 ok
7 ok
8 ok
Does it still present the same problem on the same ports if you swap the svga cables?
I swapped the svga cables and then manually toggled each port.
Main relay:
1 ok
2 ok
3 always stuck on. Is set to always be on as a pump.
4 ok
5 ok
6 ok
7 ok
8 ok
Expansion relay:
1 ok
2 ok
3 ok
5 ok
6 ok
7 ok
8 ok
Same ports are troubled, but this time main port three would not turn off, instead is stuck on.
Main relay:
1 ok
2 ok
4 ok
5 ok
6 ok
7 ok
8 ok
Expansion relay:
1 ok
2 ok
3 ok
5 ok
6 ok
7 ok
8 ok
