Code for Dosing Pumps
Hi all,
Could someone please tell me how to set up my dosing pumps with my RA. I am getting the pumps from bulk reef supply. Am I right that I need to only using the plug ins 5 and 6? Can I set it up using the generator? Can I make adjustments using the iPhone app?
thanks for the help,
Ryan
Ryan
Re: Code for Dosing Pumps
You can use them in any port and you can set it up with RAGen or Wizard
Thanks Roberto. Could I just a couple of lines of code. I already have my codes set, and don't want to have to change everything again in generator. Do you mind supplying me with the code? Does it go in the memory portion of the code or the RA section?
It goes into the RA code.
The code above runs Port5 for 4secs every 60 minutes
Port 6 is same thing, but 5 minutes later.
ReefAngel.DosingPumpRepeat(Port5,0,60,4);
ReefAngel.DosingPumpRepeat(Port6,5,60,4);
is there any documentation on the dosing pumps available for sale in the store? Do they support separate chemicals on separate ports or are they somehow all part of a single unit. Thx
Each pump head is independent of each other.
You can use different chemicals in each head.
Any documentation, pictures, etc. available? I have one BRS-type dosing pump from before I found RA, but this seems like a better solution for the money. I'd like to learn more about them prior to purchase, however. Thx.
Thanks Roberto,
I think I have it working. Is there any way to have it so that I can adjust the time that it is on without having to go into arduino and adjust every time? Currently my code is like this:
ReefAngel.DosingPumpRepeat(Port5,0,60,107);
ReefAngel.DosingPumpRepeat(Port6,10,60,107);
I have them come on 10 minutes apart and run for 107s every 60 minutes.
Ryan
Ryan
I also use a mac and an iPhone, but I do have parallels so I can run windows, it is just more of a pain
You can use this:
Then you can use the java status app to change those memory locations.
ReefAngel.DosingPumpRepeat(Port5,0,InternalMemory.DP1RepeatInterval_read(),InternalMemory.DP1Timer_read());
ReefAngel.DosingPumpRepeat(Port6,10,InternalMemory.DP2RepeatInterval_read(),InternalMemory.DP2Timer_read());
Cool. I could also use the reef client on windows, right. Thanks a Lot Roberto.
Ryan
Ryan
How would I make it run two days a week for 4 minutes each run? Thx in advance.rimai wrote:It goes into the RA code.The code above runs Port5 for 4secs every 60 minutesCode: Select all
ReefAngel.DosingPumpRepeat(Port5,0,60,4); ReefAngel.DosingPumpRepeat(Port6,5,60,4);
sunday and wednesday 9pm at nite. thx
Try this:
ReefAngel.Relay.Set(Port5,((weekday()==1||weekday()==4) && hour()==21 && minute()<4))
ReefAngel.Relay.Set(Port6,((weekday()==1||weekday()==4) && hour()==22 && minute()<4))
as far as I can tell...this is why I was watching the relay charts, this bit of code is not working:
Right now it is just plugged into a lamp so I can see it come on, and you'll notice I added some days because of my impatience, but so far nothing. Pls help. Thx
//set up dosing pump one to run twice a week for 4 minutes
ReefAngel.Relay.Set(Box1_Port2,((weekday()==2||weekday()==3||weekday()==4||weekday()==5) && hour()==21 && minute()<4));
Not sure why it is not working, I'm testing here and it does...
It is 18:26 right now here.
I used hour()==18 && minute()<27 and when the minute turned, the port was off.
are you using the weekday strings in your test? I'll try it soon without that to see if it helps. Do you think perhaps a 4 minute run is not enough to be captured by the portal relay charts?
yep, without the weekday strings works like a charm...how might I do that?
Yes, I used the weekday just like you had. all days from 2 to 5.
Is you controller date correct?
yes, just checked
this is why I love computers. I just put the date strings back in and now it works...
How is this coded: Sunday 1, Monday 2, etc.?
okay. I have been testing this for several days (with my lamp, not my pump) and am now willing to state an opinion. LMK if you think my findings are valid.
I changed my days to all days of the week and set the time to run to 25 minutes, and it is showing up on the portal relay charts like clockwork.
I believe the 4 minute run that I need for this batch of chemicals is not long enough for the portal relay charts to catch it. It is probably working just fine, but I don't see it fire, and neither does the portal.
What do you think? Thx
