Is there an easy way to edit just one line in your file after it has been sent to the controller, or do I have to edit the saved version and just re upload the changed file?
I made my ATO time out 20s ...... Which of course with the aqualifter as the pump works out real well....
Second option.... you cannot edit something on the controller nor can you retrieve it... you have to edit the .INO file and then send it back to the board....
