I have watched/read all of the beginners videos and manuals. I got my controller up and running and have been trying to edit the ATO timeout code. I have seen several threads on how this was done and tried to mimic the code. I need to extend the ATO timeout code. I upload my code but still can't change the timeout. I am using the two float switch ATO with standard ATO function. My code is below. Any ideas as to what I am doing wrong?
Thanks Ross, I decided to just let the wizard figure it out for me. It seems to be working as intended now. I just can't modify it at the unit I will have to re-upload if I decide to change it. No biggie though.
Lenny82 wrote:Thanks Ross, I decided to just let the wizard figure it out for me. It seems to be working as intended now. I just can't modify it at the unit I will have to re-upload if I decide to change it. No biggie though.
You will have to modify your code to tell it to use the internal memory instead of being hard coded if you want to be able to change it on the fly. I'm not sure if the wizard does this for the ato or not. That is something to ask roberto about.
I would actually like to be able to adjust all the settings on the fly. The preloaded code worked well for me with the exception of the ATO function. Can anyone see why the time out won't go higher than the 250ish when I try to set it? I set the value to 900 in the code and I know the cap is around 37000.
