Error uploading
MortenB
Error uploading
Post by MortenB »
Hello there. New user here. Can't seem to get far. Installed the software, Arduino 1.0.1, Development Libraries 0.9.9, RaGen 1.2.2.171, and the drivers for the cable. Tools>Board shows RA Controller w/ optiboot and Serial Port shows Com 3. Whatever I try to upload, I only get this far and then it stops and says Error uploading. I'm sure I must have overlooked a step, but I can't seem to figure it out. Any assistance would be greatly appreciated. MB
Using Port : \\.\COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x64
avrdude done. Thank you.
Re: Error uploading
Are you sure you have the standard RA and not RA+?
MortenB
Re: Error uploading
Post by MortenB »
Ugh. No, but I'm sure I was determined not to introduce myself to these boards by asking a stupid question. I have failed... Thanks for the quick response, case solved! Cheers,
MB
