I have this in setup()
ReefAngel.Relay.On(Port8);
This in loop()
ReefAngel.StandardFan(Port8,987,990);
The fan instantly turns off and doesn't turn on when triggered at 99.0 degrees?
InternalMemory.OverheatTemp_write( 860 );
ReefAngel.PHMin=830; // 830=PH10.0
ReefAngel.PHMin=430; // 430=PH7.0
ReefAngel.SingleATO( false,Port2,60,0 );
pinMode(lowATOPin,OUTPUT);
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.On(Port5);
//randomSeed(analogRead(0));
//ReefAngel.Init(); //Initialize controller
//ReefAngel.Timer[1].SetInterval(random(15,35));
//ReefAngel.Timer[1].Start();
//ReefAngel.Relay.On(Port5);
ReefAngel.AddWifi();
ReefAngel.StandardLights( Port1,19,0,6,30 );
ReefAngel.StandardHeater( Port4,740,770 );
ReefAngel.StandardLights( Port7,6,0,20,0 );
//ReefAngel.Relay.Write();
//////// ReefAngel.Wavemaker1(Port5);
/////// ReefAngel.Wavemaker2(Port6);
//ReefAngel.PWM.SetActinic( MoonPhase ) Test for Meanwells
ReefAngel.PWM.SetDaylight( PWMParabola(7,5,19,0,0,85,0) );
ReefAngel.PWM.SetActinic( PWMParabola(6,5,21,0,0,85,0) );
///if ( ReefAngel.Timer[1].IsTriggered() )
/// ReefAngel.Timer[1].SetInterval(random(15,35));
/// ReefAngel.Timer[1].Start();
/// ReefAngel.Relay.Toggle(Port5);
/// ReefAngel.Relay.Toggle(Port6);
if (hour()>=6 && hour()<20)
analogWrite(lowATOPin,0);
analogWrite(lowATOPin,(int)MoonPhase()*2.55);
//if ( ReefAngel.DisplayedMenu == DEFAULT_MENU ) //Dosing
Hours between 21 and 5
minute must be 0 (top of the hour)
seconds less than 4 (up to 5 seconds)
if ( ((hour()>=21) || (hour()<=5)) &&
(minute()==0) &&
(second()<4) )
ReefAngel.Relay.On(Port2);
ReefAngel.Relay.Off(Port2); //End Dosing
